eBay LD28 crank pirates thread
More: Auction 170153863787, ends Oct-04-07 20:37:17 PDT
I have two crankshafts and connecting rods from LD28 Nissan diesels. Story is...started with 4...built two diesels...these are parts left over. They have been setting in my shop for over a year. Both have light surface rust...however you can see where I rubbed the journal with my finger. The discoloration on the journal comes right off. Both are standard...with no bearing issues. In fact..the two I assembled back as diesels went together with standard bearings. So...after seeing previous sales, I have what I believe to be a fair reserve. Both cranks have been stored the last year just as the photo shows. If you are interested in LD28 diesel parts..I have cleared out almost everything. Still have a couple of clean heads, pump, etc. I have crankshaft boxes I will put the parts in and spray foam around them for shipping. You will pay actual shipping and costs I incure making sure they get to you in one piece.
I am listing them seperately...however if you want both you will naturally get a discount. This is for one crank and rod set only.
If you have questions, please ask. I will contact you with a reply. You may not like it, however you will get a reply. Also, if you bid and win....it is yours.
If someone wants more LD28 engine parts (maybe a 1983 oil filter base?), contact this feller in Vancouver, WA (across the Columbia from Portland).
SoCalanz
eBAY LD28 crank pirates thread
#47
Post by SoCalanz »
I must admit I may be part of that cult. About 5 years ago I was strolling around a JY looking for parts for my Z. I ran across a Maxima Diesel and my brother in law told me to get the crank just in case I ever wanted a stroker motor. Well, the crank is still sitting in my garage as I have not done the stroker yet. However, I have not put it on ebay, either. I will probably hold onto it until I build the stroker or it rusts in half!
Trying to catch some Zs? Keep on dreaming.
1983 Maxima Diesel Wagon
1992 Suburu SVX, Lsi, AWD
1995 Suburu SVX L, AWD
1972 Datsun 240z, highly modified
In my mind, there's a difference between buying a car and scrapping it for the crank, and finding a car in a JY and harvesting the crank. If it's in a JY, it's very likely never going to be on the road again.
I like the LD28 itself as an engine, and hope to keep more of them on the road. When a complete engine is disassembled for the crank, very often nothing else on the engine is salvaged. Several of us have contacted eBay Sellers of LD28 cranks to ask about the rest of the engine. Most threw everything else away, a couple have offered to sell parts for exorbitant fees.
SoCalanz
#49
Post by SoCalanz »
Thanks for not labeling me as cult member. I HAVE NOT DRANK THE COOL-AID! Hopefully I will have a use for it in the future.
I will be in LA (So. Pasadena) over Christmas., visiting Dad, hauling 1300 lbs of Onan genset to him in my Green Aerostar. Will be in town about three days. If you need help badly at that time, I might be available for an afternoon. I know Dad would be entertained if he got to come along and watch :)
#51
asavage wrote:In my mind, there's a difference between buying a car and scrapping it for the crank, and finding a car in a JY and harvesting the crank. If it's in a JY, it's very likely never going to be on the road again.
Yes, I believe the same theory, if you purchase a good running car, take the crank out of it and have the rest of the car scrapped. Because that once running car is going to the bailer. If its in the JY, its going to the bailer either way, and its just fine to pull a crank.
#52
Another one bites the dust
this one is actually going for a lot
SoCalanz
EBAY Datsun 240Z 260Z 280Z 280ZX 3.2L LD28 STROKER CRANK!!
#53
Post by SoCalanz »
$255 with over 5 days left!
We've seen a few go for up to $350. Now you know why the low-end of the diesel Maximas disappear, with no other parts recycled.
1982zxt
ld28 diesel engine
#55
Post by 1982zxt »
hi guys i have located a 128,000 mile complete diesel 83 engine in georgia
i want the crank and the owner refuses to remove it and just ship the crank. wants me to pay $250 to have the whole engine shipped north.
engine is already sitting on the garage floor.
anyone interesting in pulling the crank for me and having ALL the remaining goodies for their trouble. ip etc
everything will be done thru paypal to protect everyones interest
jim
ps: if your current engine has a ton of miles i am open to you installing this low mileage engine and send me your ld28 crank
racgibbs@nbnet.nb.ca
HowlerMonkey
#56
Post by HowlerMonkey »
There's going to be a change in the schemes of the "crank pirates" as people are now building gassers with the block as well.
http://www.youtube.com/watch?v=vEGCDkmAwbI
Thicker LD28 cyl walls allow larger overbore, isn't that the gist of it?
#58
Well, at least the block is now being used.
Thats a pretty heavy and bulky engine to be putting in a 240sx, im surprised that it fit
daftinnovations
#59
Post by daftinnovations »
wow.. stumbled along this thread looking for an actually diesel maxima to drive lol! Thats my motor in the youtube video. I built it 8 years ago to put in my 1982 gasser maxima. Once my maxima got tboned i pulled it out and let it sit for 7 years. then put some 45mm side drafts and put it in a 240z then now a 240sx just for fun. I run the diesel block mainly becuase it allows me to fit a longer rod. people take the ld crank with 240z rod and 89 or 90 mm bore to make a 3.1 or 3.2. I use a z20 6 inch rod, and 90mm ka24e piston to get a 3.2 long rod motor. has a nice rod to stroke ratio and revs 8000 with mild cam. :)
#60
If this one sells, I think the crank may be worth almost as much as the whole car.
Ebay- Auct. 150227414151
Condition: New
If you are builing a 3.1 stroker motor then you know this is the key part! These are getting alomost impossible to find now. This is a rare Maxima Diesel V07 crankshaft. I also have other parts for this stroker set up listed!
This crank has been professionally cleaned, polished and knife edged! It is ready to install!
If you are in need of quality aftermarket parts for your 510 or Z contact me direct a a2602nv@yahoo.com. .
Please check my store for other great Z parts.
DO NOT WAIT TO BID AS I OFTEN END AUCTIONS EARLY. GOOD LUCK!
These parts are becoming "NLA" which means no longer available. If you are restoring a Z than buy it now!!
