glow plug circuit problemo
Should I pursue the above further? Personally, I get kinda irked when people wont even ballpark something for me, but I am willing to continue.
I'm not sure what it would cost, but this could be done with a small 12 VDC Programmable Logic Controller. One problem would be coming up with an inexpensive temperature sender that would produce a 0 to 10 VDC analog signal for use by the PLC. Thermistors are cheap, but not linear and the calculations needed to get useful temperature data from a thermistor curve are beyond the capability of the controller in question. A thermocouple or RTD could be fed to a temperature transmitter, but this could get bulky and expensive in a hurry. Thinking out loud, feel free to join in...
- Has thanked: 3 times
I'm not interested, because it's all proprietary. Thanks for the legwork. I liked the idea that someone had done up an interface for poking values in.goglio704 wrote:Should I pursue the above further?
I'm not keen on using a PLC, but one of the small microcontrollers + interface for I/O might be cost-effective. Using analog I/O and a lookup table for mapped values, I think that would be straightforward. But I've never really liked PLCs all that much -- the couple I've worked with and had to create ladder logic programs for.
IMO, one of the problems with glow plug control is that you are never monitoring actual glow plug temperature, but rather coolant temperature. If you could monitor actual glow plug temperature and used some form of solid state switching on the power, a PID temperature controller might be a good answer. I wonder if a 7th glowplug in a well that had similar thermal properties to the prechamber could work?
So let me pose this question.
Do you really need to install an additional relay to manualy activate the glow plug circuit once the controller has cut power?
Based on the wiring schematic for the OE system, the #1 relay energizes via the controller, allowing current to pass to the glow plug bus bar.
If one were to reapply power to the #1 relay via a momentary switch mounted in the dash would there be a problem or damage to the controller?
Would it be safer to simply run another #1 relay, energized by the dash switch, tapping into the existing wiring from the first #1 relay?
I found both spade connectors at the water temp sensor completely worthless and in need of replacement. Unfortunately the temperature here now is not conducive to testing the system adequately, it's too warm.
TIA
TIA
Welcome back, Steve. It's been months since you posted. I wondered where you'd gotten off to.
No, and no. Go ahead and do it. It's what I'm going to do.glenlloyd wrote:Do you really need to install an additional relay to manualy activate the glow plug circuit once the controller has cut power?
Thanks for the tip Al. Didn't think that it would actually cause any problems but for the sake of the controller I thought I would ask anyway. Sometimes I study those wiring diagrams and think I'm right and the next thing you know it doesn't make any sense anymore.
As I mentioned, the problem could be solved with the new connections to the water temp sensor, but since the discussion has often centered around inadequate glow times I think the added manual control will be beneficial.
It has been a while since I've posted. Much has changed, little good and a lot bad, but I won't get into that here, it's just life I guess.
