The owner said it's "free to you or ... it goes to a junker." So I took a stab at getting it run and if it did start ... I could have it free.
Well ... NOTHING is a "free car." Don't ever think it is free except that a owner gets rid of it to you.
So I started for "free" and here's what I has cost (minus insurance, and yearly plates.)
1982 Datsun Diesel PL720 King Cab 120,105 miles (2-15-04)
1 Replace Ignition switch (’80 Subaru AWD part) ($27)
2 Diagnose & repair DPC controller system (no start) 4 hrs
3 Replace radio antenna 1 hr
4 Repair Controller linkage, adjust Altitude Compensator 1 hr
5 Adjust engine valves 1 hr
6 Readjust throttle cable for full throttle
7 Replace clutch master cylinder, fabricate new push rod ($65)(120,905)
8 Replace A/C idler pulley bearing ($20)
9 LOF 121,498 ($10)
10 Replace transmission oil 80w-90 ($5)
11 Pull instrument cluster, repair trip-meter 1 hr
12 Replace right High Beam ($7)
13 Replace windshield ($175)
14 Repair windshield washer sprayer
15 Install exhaust pipe extension ($20)
16 Remove & clean exhaust soot from inside tail light lenses 1 hr
17 Replace 4 burned out running lights ($5)
18 LOF 123,525 ($10)
19 Replace engine thermostat with correct part ($11) Fan Belt ($15)
20 Thread repair to thermostat housing ($35)
21 Replace engine coolant ($7)
22 Replace radiator cap ($6)
23 Replace fuel tank cap ($5)
24 Replace driver seat spring, clean interior ($1)
25 LOF 124,420 ($10)
26 Replace upper control arm & tension rod bushings, alignment ($220)(124,900)
27 Replace fuel pre-filter ($5)
28 Replace rt/frt bumper ends ($10)
29 Replace all valve guide seals ($25)(125,090)
30 Update Oil & Glow Plug lamps (LEDs) ($7)
31 Rebuild front brakes (pads, turn rotors, calipers)($80)(126,200)
32 LOF 126,451 ($10)
33 Clutch slave cylinder & hose ($55)(126,610)
34 Reset Fuel Injection timing, repair EGR controls. (126,610)
35 Rebuild transmission & Clutch complete. ($645)(127,541)
36 LOF 128,558 & fuel pre-filter ($15)
37 Rear brakes – insp, clean, lube mounts (1.5 hr)(128,558)
38 Replace muffler ($35) Driver door ($125)(129,900)
39 LOF & transmission 131,178 ($15), New A/C comp, Rcvr/drier, Condenser, R-12, Alt brushes, Vacuum Pump oil line, Lower Radiator hose, belts ($340)
40 Replace drive shaft support bearing assembly ($98 )(133,705)
41 LOF 134,001 ($10) Air filter ($10)
42 LOF 136,858 ($12) windshield wipers ($8 )
43 LOF 139,010 ($10)
44 Replace 4 Tires ($230) (140,920)
45 LOF 141,750 ($10)
46 Replace front shocks ($50)(143,370)
47 LOF 144,490 ($10)
48 LOF 147,150 ($11)
49 Replace Brake Pads ($25)(147,150)
50 Install camber spacers ($40) & tire rotation (147,440)
51 Replace Primary & Secondary fuel screen/filter ($9)($19)(147,800)
52 LOF 149,055 (Rotella 10w-30) ($13)
53 Replace glow plug set ($85) Windshield wipers ($12)(150,321)
54 LOF 151,552 (Rotella 30)($11)
55 LOF 154,505 (Napa 15w-40)($13)
56 Adjust engine valves (154,505)
57 Replace A/C idler pulley bearing ($10)(155,054)
58 Rebuild Injectors ($207)(156,787)
59 Replace Secondary fuel filter ($19)(156,800)
60 LOF 157,250 (Napa 15w-40)($15)
61 Replace Lift Pump ($100)(159,050)
62 Transmission oil (Royal Purple 75w-140)($22)(160,650)
63 LOF 161,805 (Delvac 1300)($15)
64 Replace Brake pads ($25)(162,437)
65 Transmission Oil (Royal Purple 75w-90)($22)(163,220)
66 LOF 165,305 (NAPA) $17
67 Replace Fan Belt ($16) A/C pipe and Freon ($45) (165,688)
68 Front End Work: Swap upper control arms, Left frnt & rr shocks, install sway bar, idler arm, full alignment (Part$ 130)(Labor $150)(165,901)
69 Replace water pump ($100)(166,601)
70 LOF 168,050 (NAPA) $17
71 Replace clutch, exhaust stud ($350) (171,400)
72 LOF 172,966 (NAPA-oil analyzer $17) $21
73 Realign front end (was toe-out, A-arm ok $40) (175,300)
74 LOF 176,005 ) Oil Pressure Switch ($14) (Mobil1300-Puro) $15
75 Muffler OEM 177,705 $60
76 Speedo drive pinion ($34) (177,800)
77 LOF 178,825 (Rotella 30, OEI filter) $17
78 Alternator (NAPA) $215 (181,377)
79 LOF 181,512 (Delo-100 Puro) $18
80 Replace 4 tires ($180) (181,605)
81 LOF 183,460 (Mobil1300-STP) $17
82 Vacuum pump return hose ($34)(183,750)
83 LOF 184,900 (Coastal 15w-40-STP) $14
At time 12/19/07 .... and still goin', subtotal $4,681. (revised up)
Total miles driven thus far: 65,740
Figure 30 mpg overall average: 2115 total gallons, at $3.10 average since Feb 2004 ... $6,557 fuel cost.
These' things are unique.
There is no "free" owning and driving.
