asavage wrote:philip wrote:1) Exhaust oxygen sensors .... both before and after the primary catalyst
2) The catalyst(s)
I doubt that even heavy concentrations of diesel would seriously affect either of those in the long run.
Al ... it's a new day for you.
The ECM is much more stringent about the two TWC catalysts exhaust (TWC=Ultra Thin Wall High Cell Density Substrate) than the State Of California tests for. There's two different exhaust sensors. Ahead the first catalyst is a "Air Sensor" and behind the first catalyst, a "Oxygen Sensor." Not the same ... anymore.
So when the MIL light turns ON (O2 registers the primary catalyst's 50% loss over time), the catalyst may still be lower than State but .... you'll get failed anyway because the ECM says "NO good".
asavage wrote:philip wrote:3) The ECM will catch it and trip a MIL light. Your State smog renewal is going you to fix it all.
asavage wrote:On modern cars, yeah that's a real possibility. But on anything I'm likely to be driving (ie ten years old or more), it would probably go right on through.
You "doubt" and "probably."
The OBD-II started in 1996 and the States have had tightened exhaust limits ever since.
I have a 2003 Corolla and in southern California ... which gets the most stringent emissions. You should see this Corolla's exhaust system. It's so HOT that the exhaust pipe color is dark purple starting after the primary catalyst ... clear back to the muffler (aft the rear axle). Even the muffler is gold colored!
davehoos wrote: this is not possible now to occure as new models are using OBDII, this has a second O2 sencor after the main cat to confirm its operation. Due to the unburnt fuel present the cat would rarley fire up. Australian spec cars rarely have pre cats,it may be possible with a precat and thermal reactor[air injection] to fire a main cat with a petrol/diesel mix.
People have failed 4yr and older cars (State assumes it's not necessary for the first 4 yrs). I have been heard by aToyota mech that a few fairly new cars triped a MIL needing a new catalyst because ... they used diesel fuel. DUMB. $$$.
