Leaking Injection Pump
Good morning,
I've searched for this but couldn't come up with an answer.
ON my IP one of the injector lines are leaking. Not at the nut that connects the line but just below the second nut closer to the pump. I tried to tighten it but it wouldn't move. Is there some kind of seal in there that need's replaced?
I'm getting ready to replace the injectors with rebuilt & would like to fix this at the same time.
Thanks,
Lonnie
Thanks,
Lonnie
1982 Datsun 720 diesel.
1996 Dodge cummins... 538 hp 1200+lb/tq.
Maybe Ref. No. 57 in this picture?
Different view in the 2nd pic in this post.
It's fairly common for the big o-ring between the steel distributor head and the aluminum housing to leak. Are you certain of the location of your leak? Hard area to see.
Al,
That's not my pump. Mine is an inline pump.
I spoke to a fellow this afternoon at Oregon Injection & he told me all I needed to do was remove the line & take some steel wool & clean the mating points & this should take care of the leak. He claims this is a common area on these pumps to leak.
Does he know what he is talking about? You're right, is is hard to tell just where it's leaking from!
Funny thing about the leak is it only leaks when it's cold or just warming up. If I drive it until it heats up then it stops leaking...
Lonnie
Lonnie
Re: Leaking IP
Lonnie wrote: ON my IP one of the injector lines are leaking. Not at the nut that connects the line but just below the second nut closer to the pump. I tried to tighten it but it wouldn't move. Is there some kind of seal in there that need's replaced?
Philip,
I can now see why I couldn't tighten it. To me it looked like it's leaking just above the Knerled part but now I see that it's all one pc. I suspect that it's leaking at the red arrow. So should I be able to take it apart from the red arrow, clean things up & tighten it back up?
I was trying to tighten it with the bolt assembly still in place.
You're thoughts?
Thanks,
Lonnie
You're thoughts?
Thanks,
Lonnie
1. Loosen the bolts that secure the lock platesLonnie wrote:I was trying to tighten it with the bolt assembly still in place.![]()
You're thoughts?
Thanks,
Lonnie
2. Loosen the one delivery valve that is leaking ... about one turn.
3. Now re-tighten to the spec (22-25 lb).
4. Re-tighten the lock plates ... just a little, maybe 24-30 inch pounds.
Not likely this is the leak source. Much more likely is the nozzle pipe flare tips due to damage. Both ends of the pressure pipes must align to the delivery valve (and nozzle, respectively) perfectly before you start turning down the flare nuts.
Let's see if this seals.
OK Al,
Bang!
Not a problem!
Philip, I took the set of lines off tonight. 3 of the 4 fuel delivery valves were loose & I mean I could take them out with my fingers! #1 was so tight I couldn't get it loose without really reafing on it, but 2,3,& 4 & turned with my fingers...
So I went ahead & took lock plates off & turned them back one turn & then retightened per your specs. I would think this should fix the leak.
I went ahead & removed the injectors & will send them to Oregon Injection tomorrow. They are going to rebuild my core & send me new washers for $45 ea. so I didn't think that was too bad of a price.
I fished around & tried to get the copper washers out but that looks like it will be a bear...
Thanks again for your help!
Lonnie
Bang!
Not a problem!
Lonnie
Received my rebuilt injectors yesterday & installed them this morning.
WOW
what a huge differance! & Philip... no injector pump leaks! I can't believe how smooth it runs now.
Before it smoked like crazy on the first start in the morning if it was even just a bit cool out. This morning it was 34 deg. & only a little puff of black smoke!
Yep, I'm very happy!
On my way to work there is a 5 deg. grade about one mile long. Before I could just bearly make 45 Mph in 4th & this morning I hit 55 & was still climbing before I got to the top.
Now I'm hoping that I'll get better mileage as I've only been getting around 24 in town & 28 hwy.
Lonnie
WOW
Lonnie
- TooManyIdeas
Hey Lonnie, does Oregon Injection do mail order rebuilds? Every diesel shop in ABQ wants no less then $150 per. Do you think you could hook me up with an address?
85 Chevy Monte Carlo CL
90 Toyota Pickup -SOLD
05 Kia Spectra 5
02 Dodge Dakota Quadcab
-OOOOOOOOHHHHHHHHH YEAH!!!!!
05 Kia Spectra 5
You can Google OFI for their address. Their contact info is here. I'm pretty sure they do mail order no problem. OFI seems to enjoy a decent reputation.
Today, I sent off a Toyota Nippondenso-licensed Bosch-VE-style IP to H & H Diesel in Milton, WA. $650-850 for overhaul, typical for a VE.
- TooManyIdeas
I dealt with a fellow by the name of Jim at the Eugene location.
They charged me $45 ea + shipping to rebuild the injectors. I just pulled mine & mailed them to them & they had them back to me in less then a week.
I'm sure they would do the same with a pump...
Lonnie
Lonnie
