Parts cleaning brushes
I've bought various parts cleaning brushes over the years, but two years ago I found one I really liked, found by accident at the local FLAPS in the bodywork supplies section. When I bought it, they didn't know where it came from nor the part No. and so they sold it to me for a buck.
It started getting pretty worn after a year, so I went back to get more. Holding it my hand, I tried to order it, but what they brought in wasn't the same thing, the bristles were too flimsy. They said they could not locate a supplier.
I have spent way more time trying to find this brush than you would think would be necessary, ordering one from here, one from there, but today I finally received the right brush.
From MSC Direct, Pro-Vend branded (probably a Weiler rebranded), MSC's part No. WU09301748, $1.38 ea. on sale:
MSC Industrial Supply Co. wrote:
Description:  	Welder's Brushes - Toothbrush Style
Type:                   Welders Brush
Brush Material:      Nylon
Type: 	Welders     Brush
Brush Length (Inch): 	1-1/2
Trim Length (Inch): 	1/2
Overall Length (Inch): 	7-3/4
Handle Material: 	Plastic
Number of Rows: 	3x7
Doesn't look like much, does it? Best I've used so far, for anything other than large pieces.
This brush has fairly firm bristles. Aerosol carb cleaner will not melt the nylon bristles nor the handle. Survives Castrol SuperClean lye solution well. Good for a couple of hours of cleaning, which is way beyond what most brushes will do.
If you've ever tried some of those small wire bristle brushes (either SS or brass) you know the misery once you bend the bristles over: they become useless. This nylon brush is the one you want.
Re: Parts cleaning brushes
Type:                   Welders Brush
Type: 	Welders     Brush
Number of Rows: 	3x7
Doesn't look like much, does it? Best I've used so far, for anything other than large pieces. -snip- This nylon brush is the one you want.
Truckers use them for scrubbing their teeth.
I get beat up by my dentist every time I'm in, I brush too hard and have damaged the gumline, so I had to switch to soft bristles.
I used to use toothbrushes for parts cleaning but none of them would stand up to the harsher chemicals, go figure.
How often do you scrub your teeth & gums between dentist service? :wink:
At least once: right before I go in for a cleaning, of course!
TooManyIdeas
Post by TooManyIdeas »
EWW
85 Chevy Monte Carlo CL
90 Toyota Pickup -SOLD
05 Kia Spectra 5
02 Dodge Dakota Quadcab
-OOOOOOOOHHHHHHHHH YEAH!!!!!
