I need help to figure out problem!
nissandieselcrazy
Post by nissandieselcrazy »
I think I blow head gasket but I'm not sure. driving home last night started losing power some puffs of black smoke from the exhaust, then a a LOAD POP from under the hood, then white and brown smoke from under hood engine will crank but will not start. Dose anyone know where to get a head gasket and exhaust gasket ???
kitchenerlarry
sounds real bad, hope it isn't
Post by kitchenerlarry »
I "had" a very simular problem 2 weeks ago and you're not gonna like the results. It got real hard to start so I had the starter rebuilt in town for about $35.00 It turned over and ran louder and lotsa smoke. I took to valve cover off( only 2 or 3 bolts) and had a look. I broke a rocker arm. To see why, I pulled the head and found the remnants of a turned and broken valve insert. So now I got 2 alternators ( reg and high cap, rebuilt starter and all the goodies like glows, fuel pump etc, for sale if any one needs parts.
Thanks and good luck :?:
kitchenerlarry
Almost forgot to tell ya where to get stuff
Very unlikely you'll get help from Nissan or the wreckers. There's some parts at NAPA but honestly, for the best price and quality, visit your local lift truck parts supplier for that engine. My guy in town at ryder lift truck kitchener had darn near everything at remarkable pricing. This engine was so good, when they stop auto running them, they put them in generators, boats and lift tucks. Not only are the SD22,25 and 33 interchangable, so are industrial, marine and auto
Hope that helps Larry
nissandieselcrazy
Well after some investigation I have found out the I need a head gasket and a manifold gasket.
