ip code
ruthless79
ip code
Post by ruthless79 »
i am needing the code on the side of the ld28 injection pump that is PExxxxxxxxx i am needing this info to see if i can use the pump in a custom project thank you for time in advance
An NOS (brand-new) 1982 LD28 IP:
A used 1982 LD28 IP:
More pics of the new IP are in this post.
ruthless79
thank you for the link i also would like to know if someone has built one of these for serious power
The stock LD28 IP already supplies more fuel than can be used with the stock breathing.
To get more power, a turbo is needed. See this post and most of the rest of the thread for info on how to add a turbo inexpensively to an LD28.
Once you've added a turbo and added more air to the combustion chamber, to get more power you need to then add more fuel. To do that, a boost aneroid compensation device ("LDA") needs to be added to the top of the IP. See this post for a cutaway on that device. If you try to turn up the IP delivery rate instead of using a boost controller LDA, you'll have lots of smoke and increased EGTs -- not good.
See this post for info on having the LD28 IP modified (by a professional) to accommodate the LDA from a different VE-style IP that has a turbo (ie the Volvo/Volkswagen turbodiesel Six). Swapping out the top over and retaining the LD28's throttle shaft etc. might be able to be done by an adroit home mechanic.
I do not know if the LDA and IP top cover from a VE-style Four cylinder IP will fit to the LD28's IP housing.
HTH
ruthless79
thank you again i had read 2 of the post before what i am more after is if the ld28 can handle 20+ of boost i would like to build a small car diesel with some serious power if the ld28 can not handle that kind of boost i may just build a mercedes om603 or om617 diesel as for the ip i was wanting to know what size the plungers where it looks like 10mm for it i was hoping it was an inline pump hence the asking for the pexxxxxxx code thanks
The Inline IPs won't rev -- well, they'll rev but are inaccurate at high speeds. The LD28 is a high-speed diesel and runs smoothly at above 4,000 RPM. The OM617 does not.
I don't know whether the IP used on the LD28 has a 9mm, 10mm, or 11mm plunger, I've never been into one that far. I'm reasonably certain that the plunger and distributor head from any other 6-cylinder VE-style IP would be a bolt-on.
Whether you can reliably push 20 lbs boost is a whole 'nuther issue. The LD28 is not a B-series Cummins. You'll need better pistons to do that much boost. I may be wrong, but I don't think the LD has under-piston oil squirters, and lacking those the heat can't be shed fast enough.
Stick with 7 lbs or less (light-pressure turbo), keep the fueling reasonable, and I think it will hold up. But if you need a reliable 160 HP 2.8l Six, when it was designed for 80 HP, look for a different engine. It's a good mill, but not that good.
