SD22 engine mounts = SD25 mounts??
after oil
Post by after oil »
im just curious will an SD22 bolt up into a truck with an SD25 stock? and do the tranny's bolt up?
from my experience i understand that the blocks are pretty much alike.
Re: SD22 engine mounts = SD25 mounts??
after oil wrote:im just curious will an SD22 bolt up into a truck with an SD25 stock? and do the tranny's bolt up?
I would expect: yes, and yes. Perhaps someone with direct experience will chime in.
The SD25 block has five mains rather than three, and a real rear main seal.
after oil
Post by after oil »
"mains?" could you please elaborate?
after oil wrote:"mains?" could you please elaborate?
I belive Al is talking about the main crankshaft bearings
after oil
Post by after oil »
understood, thank you.
