ive got myself a 1987 Nissan Vanette gen 2.
it's running a LD20-II diesel engine (not the turbo...that's the LD20T i think)
but about 8 years back they changed the diesel fuel mixture, and hence we get this stuff called "low sulphur diesel"...umm well this has kinda screwed my fuel system seals over
over the years they seem to have deteriorated and now there is diesel all over the injector side of the engine. so on long trips you can smell the vapour comming off the hot engine.
so i need a seal kit...and i dont know where to get one from...reckon i should try ripco? (repco)
and do i really need to remove the engine from the vanette to do the job..cause removing the engine seems like a BIG job but so does trying to replace seals down that side of the engine
while the engine is out i'll do the timbing belt aswell.
is there anything else i should do to the engine while it's out of the van?
and is there any seal kit you goys would recomend?
is there a better engine (diesel) that will fit in there from other cars?
what number is on the injector pump?
hope you can help me
shaun
