Hunting surging at idle
rock1
Post by rock1 »
Hi, the LD28 in my boat has started hunting, surging at idle. The fuel filter was changed around 3 months ago and has only done 15 hours running at max. I would be very grateful for any ideas. Thanks Pete [/b]
Marine LD28
Have you checked for air leak in the fuel path pre-IP? Presuming your marine application does not have an external lift pump, other than the one inside the IP.
rock1
Post by rock1 »
I have had a quick check but will look again when I am down there next. It only does it sometimes and only after its been running for a while. it doesn't seem to do it when its cold. Thanks Pete
Marine LD28
dieseldorf
Post by dieseldorf »
Does it smoke a lot when its surging?
Engine may suck in and burn oil from intake due to large blow-by.
rock1
Post by rock1 »
Thanks, no it doesn't smoke at all and is only doing it sometimes so it has got me stumped.
Marine LD28
