Anyone with good components laying around.
The DPC is making a loud buzz sound and the IPC is making the screech sound reported in an earlier post.
Are these repairable?
Need a DPC and an IPC.
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
Anderson , SC
Since Fall 2009
I have several used, tested IPCs.
I have one NOS (brand new) IPC.
I do not think I have a DPC Module that I can spare. The part that dies is the relay. Philip did a pretty good write-up on replacing the relay itself in this thread.
I can probably repair either of yours. They do seem to be repairable.
New, they are not cheap:
The DPC Module (black box near right hood hinge, two plugs) is Nissan
No. 19850-31W02, $184 (if available)
The IPC Motor is Nissan No. 19811-36W02,
$359 (if available)
$359 (if available)
http://nissandiesel.dyndns.org/viewtopic.php?p=17276
Where is the idle bearing you mention located.
I have watched and read a number of these since yesterday.
If my relay is bad, where do i get a replacement?
Yes, i am willing to ship my parts for repair.
What is my next step Al?
With the DCP black box bad, does this disable the starter?
It will not start or shut-off with the key. I can push start it.
Anderson , SC
Since Fall 2009
Anderson , SC
Since Fall 2009
