Fuel tank Question
dieseljunky
Fuel tank Question
Post by dieseljunky »
Hello. I am in the process of doing an engine swap. SD22 into a 1987 D21 Hardbody.
I was wondering if I could use the original gas tank as my diesel fuel tank?
Or would it matter if I made my own fuel cell?
Let me know your thoughts about putting diesel into a previous gas tank. Thanks.
Go for it! My converted Ranger uses the original gasoline tank. I had to remove the OEM fuel injection pressure pump from what became the pick-up tube and dry out the tank. All is good!
exsimguy1
Post by exsimguy1 »
Diesel fuel has occupied my D21 (gas) tank for over 15 years with no issues. Removed the fuel pump and replaced with copper tube. Used the original float and sender.
Terry
exsimguy1
Post by exsimguy1 »
Terry
There is this link to have a look at and bear in mind.
http://nissandiesel.dyndns.org/viewtopi ... 0705#10705
Not saying to do or not to do but just have a read and make your decision after that.
I know when I inquired at Nissan for my 87 D21 that there was a specific fuel tank listed for the Diesel application.
P
dieseljunky
Thanks for the info guys. I will figure out what will work best for my situation. Can't wait to get a tank figured out so that it is out of the way.
