Where can a lova find a compression tester adapter for the blue pearl 720 82 pu?has any one tested compression from the glow plug holes?
we are willing to rent and leave all the cash down to borrow adapter for a couple then return with the magic you so desire.
we live in south seattle.
cheers.
byrdlova 206 227 2385
720 sd 82 pu compression test adapter
I have two custom GP hole compression tester adapters for the SD engines, and I do rent/loan them and the gauge set out. See the bottom of this post.
