L4N71B TRANNY
benboodoo
L4N71B TRANNY
Post by benboodoo »
hi im new to this : can somebody help me with my l4n71b transmission? i went to do a engine wash and forgot to put the tranny dipstick back , when i got back it worked for a couple days and stoped , i send it to the repair shop and when it got back it was not the same ; i went back to repair shop and these people dont no what is the problem, so came home and took it down got the pan out and there was fragments of the band in there , went bought 1 put it on and mount up fill oil and start , i in d and nothing was moveing i put in r same nothing, went and tighten the band it started to move after several adjustments it worked a little better 2 days passed and it started to get tight while driveing, when letgo the throttle it stoped like brake was on, a little while after it started to work again , i try adjusting again and nothing seem to b working, it cost me alot of cash already, im trying, cuold u please tell me how can i adjust these bands so it can work normal?
I'm not an expert by any stretch, but my understanding is that if you get significant water in an automatic transmission, all friction plates must be replaced. The water destroys the frictions.
Seals, bearings and such should survive OK if the water doesn't remain in the trans for very long.
This was a problem that used to crop up every so often when a transmission's radiator tank cooler sprung a leak and got antifreeze in the trans.
benboodoo
L4n71b tranny
Post by benboodoo »
yeah k, i got a used 1 at a reasonable price i put it on myself but for some reason its not working like it should I swiched modulator frome both but it
still shift too fast, is there anything i can do to solve that prob ?
It upshifts too quickly (at too low of a speed)?
The first thing that comes to mind is too much vacuum at the modulator valve at the transmission. The amount of vacuum there is controlled by a valve that's mounted on the injection pump, with a little adjustable linkage.
You might want to read more about this in this post. Take a look at the vacuum schematic:
The vacuum line from the vacuum pump probably has a small orifice, and the valve on the IP bleeds off vacuum to the air filter housing. If the line to the air filter housing is plugged, or the valve on the IP is stuck shut, there could be too much vacuum reaching the modulator valve on the transmission.
You'll want to use one of these to check vacuum at the valve on the IP, and possibly at the modulator on the transmission.
These things are cheap to buy, even new. Google "fuel pressure tester vacuum" and you can find a list of them. Like these:
benboodoo
Post by benboodoo »
ok I will get that guage today and follow instructions let u no what happens.
THANK U ALOT ill get back to u.
benboodoo
Post by benboodoo »
hey thanks alot for ur help i did what u said and u were right !! my tranny workes realy good now, I got called out to work now and everything worked out just fine and in time for my job, thank u again!!!
Users browsing this forum: No registered users and 154 guests
