Changed fuel filters, can't get truck started
So, I changed out the fuel filters in my truck the other day and now I can't get the thing going again. From what I can tell it looks like fuel is not getting to the injectors. Gathering from what I've read on here, I need to maybe bleed the fuel lines and get the air out of the injection pump, but I haven't come across anything that explains in detail how to do that. I need a dumbed-down, step by step process. Keep in mind this is my first diesel and pretty much the first vehicle I've ever tried to anything more than change the oil on. I am dedicated to learning all I can about this, though. Thanks for any help!
Hopefully you have not had to wait too long
What truck do you have, a 720 with an SD22/25 or a D21 with SD25 ?
It's a pretty easy process with the SD22?25 in the 720 truck.
There is a hand pump on the side of the fuel pump that you unscrew and then pump the air out through the bleeder screws. Once you get the truck to fire the rest of the system will bleed itself
To elaborate on Paul's advice:
The Inline style injection pump has all four high-pressure injection lines pointing straight up off the pump.
The Distributor style injection pump has all four high-pressure lines coming horizontal off the back, pointing to the firewall.
Most 720 pickups with the SD diesel in the US are the 1981-1982 years with the Inline pump.
There are two bleeder screws on the top of the Inline style injection pump that you loosen 1/2 turn, then you operate the hand primer pump.
If you have a Distributor style IP (ie a 1983 or newer, or an SD25) then the procedure is different, but few have that IP; let us know if you do.
For the rest of the Inline style bleed procedure, see these threads:
FUEL FILTERS (SD)
Using the priming pump.
FUEL FILTERS (SD)
