well today I purchased another sd 25 truck. a 720 this time which I had fixed for a friend last year who owns it locally. only other sd25 running in a vehicle still that I know of anywhere nearby. So why not right? well last year the truck went through 2 sets of glow plugs before he finally gave up on using it and bought a vw. fair enough
I got it home only to stick a fresh set of glow plugs in. Didn't even get a sputter and I rewired the glow system last year to all manual control. I checked my work again and could not find an issue... puzzled I started swearing at the glow plugs. my ohm meter doesn't lie. 20 meg ohms.... gross....
so I went over to my 4x4 sd25 and looked at the glow plugs which seem to just keep truckin... glow after glow they take torture. hmmm... maybe this picture can explain.
for those who can't see it
the parts people have now sold me 3 sets of glow plugs that burned out way too suddenly
part#s on the plug
NGK
0373
Y-112RS1
10.5v
the oem glow plug box I have and the plugs in my 4x4 both read a common part #
NGK
Y-705RS
0524
11v
so the plugs are not the correct part number. and they look exactly the same.
in my picture I highlighted all the common numbers between the plugs that should be correct. you will notice the 4 digits will change but the part number stays the same until the wrong plugs I just purchased. there is also an oddball lucas plug I found... not sure if its correct.
if anyone wishes to add anymore to this it would be appreciated.
