eBay, IN: 1985 720 KC SD25
Auction 260004695909, ends Jul-08-06 19:52:04 PDT
1985 Nissan pick up with 4 cyl diesel engine with 5 speed tranny. ...I purchased from the orig owner and have manuals and service records........This truck runs, drives, shifts very good..... It runs within normal operating range with the gauges.......I have not had to add any fluids since i have been driving it......It has very good tires and good brakes.....I have used it for a daily driver for a couple months and it always starts and gets high 30s to low 40s MPG....As far as i know everything works on the truck.....The windshield has a crack on the bottom ......It has the usual rust for the year but the structure and frame are in good cond...........The fiberglass topper is included......Yes it also has a clear title........If you are looking for a good transportation vehicle with good fuel milage this truck is for you.......I see these trucks go for over 2K on Ebay with mechanical problems and this 1 i would drive cross country with confidence.
