Junkyard Grocery List
- TooManyIdeas
I'm looking to do alittle strolling at my local junkyard and I was wondering about year interchangability diesel vs gasser parts and different makes altogether. I'm not looking for anything in particular. I only want to know about swappable parts
85 Chevy Monte Carlo CL
90 Toyota Pickup -SOLD
05 Kia Spectra 5
02 Dodge Dakota Quadcab
-OOOOOOOOHHHHHHHHH YEAH!!!!!
05 Kia Spectra 5
The battery hold-down bars are largely interchangeable across all years.
The transmission guts can be interchanged, though the ratios are a little different -- I've done it. The front half of the trans case is different to accomodate the different starter location of the SD.
All body panels interchange. The fuel tank is unique to the diesel, due to the lack of internal galvanizing (zinc & diesel don't get along). The gasser's dash tach won't work with the diesel.
I think that the radiator is different -- different inlet/outlets.
- TooManyIdeas
more specific
Well lets see
I find all the bushings to replace a sway bar but no swaybar so lets start there. What years will fit the 82? will gassers work or is the diesel suspension more heavy duty.
Same with the power steering assembly. My truck doesn't have it and that sucks so I want to retro fit. Again what years and will gassers fit.
My radiator support is all jacked up so I need a replacement one of those. Then there is stuff like cruise control, different bumpers, fenders, doors? will later year hardbody's work
05 Kia Spectra 5
05 Kia Spectra 5
Re: more specific
Any year 720 2wd anti roll bar will fit. Engine type does not matter.
Power steering pump (divorced reservoir), bracketry, and idler pulley are unique to the diesel. I'm not sure about the number of pulleys on the crankshaft. For my SD22 with factory A/C, there is one for the W/P & Alt, and a second smaller pulley for the A/C compressor. Armstrong steering is fine until you mount wider tires.
Re: more specific
Good stuff.
As Philip said, it's unique to the SD engine, so you'll have to find a diesel to provide the bits. And I can tell you that SDs with PS are pretty darned rare.TooManyIdeas wrote:Same with the power steering assembly.
Interchangeable, 1981-86, AFAIK.My radiator support is all jacked up so I need a replacement one of those.
I do not know if it was even available for the diesel. Even it it were, modern aftermarket CC kits will work much better. I installed an aftermarket kit last year on a rig (not a diesel), and it works extremely well.Then there is stuff like cruise control . . .
All interchangable, all years and all models, except: Taillights changed in ('83?), and that means that the bed changed too. You can interchange the bed + rear bumper together between all years -- keeping in mind the variations in bed length.bumpers, fenders, doors?
Don't know. Peter's "Bellingham Truck" is an '82 KC with a hand-shortened D21 bed on it. Looks weird. I haven't looked to see how it's mounted, but I suspect that it's more or less a bolt-on. Hard to say, since it was a std bed that was shorted to fit on a KC chassis -- or more properly, shortened to fit a std chassis that has a long KC cab on it.will later year hardbody's work
- TooManyIdeas
power steering
Is it unique to the diesel because of bracketry or because of RPM's if its bracketry, thats not a problem I can make it fit
by fabbing up some new brackets
05 Kia Spectra 5
05 Kia Spectra 5
I don't have an '82 FSM right now (sold it to a member who needed it more than I do right now), but in the '84 FSM, pg ST-14, there are pics. The pump for the gasser and SD engines is a different pump, the reservoir is remote mounted for the SD, integral on the Z24. On both engines, the pump mounts on the passenger (right) side of the engine.
The power steering gearbox looks to be identical for gasser & diesel versions, so that wouldn't be a problem. If you can hang a PS pump somewhere and drive it, you can fiddle with the pump's sheave diameter if the flow is too low or too high. But you'll fab the brackets and the pressure hose, all custom.
Re: power steering
As I mentioned eariler, the diesel version has a divorced (remote) reservior and fittings to make that possible do to the location. The pump iteself is the same however ... there are fittings required to remote mount the oil reservoir. Notice too there is a different angle on the hose fitting on the rear of of the pump body and that the sheave (drive pulley) is smaller.TooManyIdeas wrote:Is it unique to the diesel because of bracketry ...
On the SD25, the IPController for the Injection pump was rotated 90 degrees to give the P/S pump more room.
All this is covered in the ST section of the FSM.
