New Member JoaoCabrao's 83' Maxima Diesel
JoaoCabrao
Post by JoaoCabrao »
This is my rustbucket, about 119k on the odometer and runs like a champ. I have the original rims off of the car because a couple of the acorn lugnuts stripped and I ordered replacements. Nice to see a website dedicated to these diesels. Only problem I have with this car is alternator hum coming through the radio, does anyone know how to solve this? Thanks.
________
YAMAHA SR250
Re: New Member JoaoCabrao's 83' Maxima Diesel
Sharp Maxima!!
Alternator whine is usually a symptom of a failed alternator diode. You simply replace the whole diode bridge assembly.
JoaoCabrao wrote:This is my rustbucket, about 119k on the odometer . . .
[Jaw dropping]
That thing looks as if it's a 1982 sales brochure! I've never seen one so . . . shiny! Is it MT or AT?
119k is very low miles. I bought my '82 from the orig. owner in 1997 (it came from Penn.) and I paid premium price because it had 86k on the odo (has 155k now).
Could be the external noise suppression capacitor has died -- this was not on all alternators. However, I suspect that Philip's right. Put a DVM on the big lead on the back of the alternator and ground, set it for AC voltage, turn on the highbeams, see if you have more than 0.1v. If so, buy the $80 rebuild on eBay. Remember, this alternator is special, due to the extended rotor and special rear housing to drive the vacuum pump.
JoaoCabrao
It's an AT 3 speed OD, the previous owner had it resprayed at a macco I would guess. The car isn't terribly rusty but what rust there was they bondo'd over it and never properly repaird it, it's starting to rear it's ugly head again and I'll have to take care of it. Yes 119k is low, I have only put about 5k on it since I bought the car a year ago. It sat because the crank pulley, harmonic balancer deteriorated and no parts were available. I found a replacement in a salvage yard somewhere. Only problems I have are the alternator whine, I think I have the driver side door typical crack I read about on this board and now a rack and pinion leak but already have a rebuilt rack waiting for to be put in everything else works. Sunroof all four power windows, power mirrors, cruise control, power ant., radio, tape deck, power locks, etc. Oh and in the background you can see a little bit of my dad's 76' AMC Matador, 33k original miles and not even the smallest bit of rust. Thanks for the tips guys I'll fill you in on the outcome.
________
HONDA 1300 HISTORY
