eBay: 1982 Sedan, 43k original miles! Ends 28-Dec
http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4598783355
Wow, I've never seen such a low-miles one before.
I'll guess that it goes for somewhere north of $4k.
Re: eBay: 1982 Sedan, 48k original miles! Ends 28-Dec
asavage wrote:http://cgi.ebay.com/ebaymotors/ws/eBayI ... 4598783355
Really...you think it'll bring that much...wow. Wonder what a "brownie" wagon would bring! BTW, in the underhood photo, in the vacinity of where my fuel filter / primer pump is located there's a huge canister object that doesn't look remotely like my fuel unit. I know you probably know what it is....and I'm sure it's a fuel filter of some kind....but...???
SA
I saw a wagon in Florida last year go for almost $5k, under 100k.
Yes, I saw that cannister, and suspect it's an aftermarket filter, but it might not be for fuel. Could be an oil bypass filter -- it's so large. I own a couple of those, but none with a bolt-on top (most are clamp-on).
If you look at the undercarriage pics, you can see the stock fuel filter lower than normal, behind the oil filter, with the "Water in Fuel" sensor and wire still attached.
i would have to say, that would be one of the cleanest maximas ive ever seen.
-83 maxima
Looking at the undercarriage shot, it's been parked over dirt for some time. My undercarriage looks at least that good, maybe better, and my muffler isn't creased!
But it's interiour is sure nice! Mine's well worn and stained, though intact.
Unless the paint was hiding something, which it might have, this car did not bring what it should have. I expected it to at least get to $3.5k, and it would not have surprised me if it got to $4k.
SA
