Fan Shrunk! Bad Motor Mounts?
Spent a lot of time under the hood this past week. Stuck at home, snowed in.
Noticed the radiator fan shrunk almost 1-2" in diameter! Huge space between it and the top of the radiator shroud, almost no clearance at the bottom. Driver's side motor mount looks sound (although I'm not really certain how it should appear), passenger side a little hard to inspect, need to take a closer look in good light.
Anyone else seen this?
Finally able to get under the car to snap some pics. Could anyone compare to their car and see if mine have collapsed? New mounts are $50 each, special order and I'd rather not go thru all that process unless my motor mounts truly need replacing.
Here is the driver's side motor mount, from underneath the car, rear looking forward thru the power steering lines, frame rail to the left, engine to the right. Judging from the metal brackets it looks like it has collapsed but I don't know what it is supposed to look like:
My guess is that the rubber block should be somewhat more vertically centered in the U-channel outer housing, the part that bolts to the frame crossmember.
Another shot, from above:
And another, closeup:
This one shows the fan almost scraping the lower shroud, there is of course plenty of clearance on the sides and between the fan and upper shroud:
Misc. info: Mount upper nut is 14mm, lower nut (hidden in crossmember extension channel) is 17mm. Driver's side definitely much easier to access.
sounds to me like they are collapsed, but I cant compare at this exact moment cause my car isnt here, also its a gasser, not a diesel, but the mounts are probably the same
diesel-man
Post by diesel-man »
It is a common problem, probably due to the awesome torque of the LD28 or the slight chance of the passage of 25 years of time. Too bad that Nissan didn't use the same vendor that made the hoses, for the mounts.
How many people have had a maxi diesel hose give out? How about a poll? If you just wanted to have new hoses, your vote doesn't count. :cry:
dlh
Post by dlh »
I have a hard time believing the motor mounts collapsing enough to cause the fan shroud damage like that.
How is the rear transmission mount?
1982 280zx turbo 4 spd auto
1973 240z, lsd, cv axles
dlh wrote:I have a hard time believing the motor mounts collapsing enough to cause the fan shroud damage like that.
Tranny mount seemed OK, probably post some pics of it later, for comparison. I would think if the tranny mount failed the front of the engine would be tilted up when at rest, not down.
Been thanked: 7 times
Mine on the '82 look much the same as yours. You did better taking pics than I.
LH:
RH
I do have a resonance at certain engine RPMs at certain loads, but I'm thinking it's either a deteriorating rear exhaust hanger, or the tailpipe is a bit too short and I'm getting resonance between the road and the rear. It's not very bad, except it's annoying on one steep 30 MPH hill (speed limit: 30) I climb every day.
I have at least two spare new OEM trans mounts (for AT) and one motor mount (aftermarket, LD28, but I don't recall which side). Want me to try to remember to take pics of them?
asavage wrote:I have at least two spare new OEM trans mounts (for AT) and one motor mount (aftermarket, LD28, but I don't recall which side). Want me to try to remember to take pics of them?
Thanks for the in-car photos. Pics of the new ones would be great if not too much of a hassle. Otherwise a visual comparison of the new to old ones would be worthwhile. So far, our in-car mounts look identical. I can't help inferring they are collapsed by looking how they are sitting in place with the metal parts of the frame and engine sides practically touching.
diesel-man wrote:It is a common problem, probably due to the awesome torque of the LD28 or the slight chance of the passage of 25 years of time.
diesel-man, sounds like you are talking from experience. How many motor mounts have you had to change in your Maxi fleet? Could you tell from my pics that mine are bad?
diesel-man wrote:Too bad that Nissan didn't use the same vendor that made the hoses, for the mounts. How many people have had a maxi diesel hose give out? How about a poll? If you just wanted to have new hoses, your vote doesn't count. :cry:
Had to replace the radiator overflow hose-- maybe that is not fair-- couldn't tell if that one was OEM.
diesel-man
I have not replaced any. It is more like the "old Woman living in the shoe" too many Maxi's, to worry about restoring them. The fan will wear as gravity takes it's toll. I keep up what is necessary though. There ara a lot of crazy things about these Maxi cars... the rear struts are crap, the front ones are great. I've only had to replace maybe two hoses out of many on the fleet. Rear calipers are so so, front ones are great, etc.
diesel-man wrote:... the rear struts are crap, the front ones are great. I've only had to replace maybe two hoses out of many on the fleet. Rear calipers are so so, front ones are great, etc.
The rear struts are just terrible, too undersized for the vehicle
Carimbo wrote:Pics of the new ones would be great if not too much of a hassle.
The LD28 motor mount is the same for both left & right sides: 11220-W2500, for all years.
This is one of the transmission mounts: 11320-W2500. It fits all MT LD28s, and AT LD28s to Jun-82. (All ATs (gasser & diesel) from Jul-82 have a completely different rear crossmember and twin/smaller/softer(?) mounts)
Thanks again, Al, the pictures are worth a thousand words. By comparison, the ones in our cars are too far displaced along the y-axis, and the isolating rubber too far compressed. My fan blades are taking a toll, and yours... well, I hope it doesn't get that bad before you get a chance to change your motor mounts.
The tranny mount photo was helpful also-- looks like mine should be changed also.
I wonder if this is why my Blue car is so much noisier than the other two. Maybe I have noise coming through the motor mount. I did notice that the extra fan that I got with the Texas car has wear on the tips of the blades.
New mounts arrived today, installed them before dinner! Would have been faster but the passenger side mount did not want to come out, engine would not raise enough on that side. The hangup was the damper. Unscrewed it and the mount practically fell out by itself. Damper damps, BTW.
Here are some comparative photos:
This shows the driver's side new mount installed-- compare to some of the above photos from my or Al's car:
Paint on the rubber is flaking.
Side by side comparison:
Old mount overlayed on new; shows offset difference of isolated to frame:
Old mount overlayed on new; shows thickness difference:
Results: More space between fan and bottom of shroud; not equidistant to top however.
Drive test results: Not yet! It's Dinnertime! Kid's hungry!
Users browsing this forum: Bing [Bot] and 33 guests
