I want a TACHOMETER !
- Knucklehead
I like the 5k autometer. The "inductive probe straps to the alternator" solution is easy and the meter itself is adjusable to alternator RPM.
If I had to choose between the tach vs. a pyro .... I'd take the pyro. I can hear rpm but, I can't feel exhaust heat.
- Knucklehead
olpeppy
tach
hello all, been a while since i posted anything, been busy on alot of different things. my 84 sd25 has a removable cover where the revolution sensor goes. was going to show a pic but wasn't sure about the different procedure to do it. it would be nice to do but the price is far from my limits. i have checked in the past on a tach from nissan dealer and was told it was $275. that wasn't including the revolution sensor. anyways phillip i hope all is well your way and good wishes to all.
http://www.autometer.com/ (catalog)bacho wrote:Anyone know how much that autometer runs?
http://autometer.carshopinc.com/product ... /8515/2888
5000 RPM DIESEL TACH
AUTO METER 2888
- Has thanked: 5 times
Here's a tach setup from member "Tom Young"'s boat engine, which does not use that sensor hole, but rather a timer cover adapter:
I'm certain that I would not want to use the rocker bolt as a ground point.
The gauge looks quite good in the clock location
- Zoltan
No,not at all !! I find the refresh rate perfect.moose60 wrote: Is the slowish refresh annoying?
Worked so far... I guess it can be inconvenient if the valve cover is removed frequently. I will probably find an other spot for the ground next time I have to remove the cover.asavage wrote: I'm certain that I would not want to use the rocker bolt as a ground point.
philip wrote: Bravo !! I just need a magnify glass over it.
When the engine is not running the tiny tach shows total service time on the engine (in hours and minutes). Could be used as an indicator when to change oil.
- Zoltan -
'86 Ford Escort 2.0L Diesel
Driving at 60mph in 5th gear, what is the RPM?Zoltan wrote:philip wrote: Bravo !! I just need a magnify glass over it.I know what you mean...
And at 38 mph in 3rd gear, what is the RPM?
More views of the same:Knucklehead wrote:In all practicality it doesn't make any difference because, 1.) the tach, which does have a different part number than the Z tach, is $217 (the gas one is $229). Moot, because it is not available anywhere, at all. 2.) The sensor (pn 25068) is about $60. Rush to your dealer now, because there is one somewhere in the US. 3.) I can't imagine finding a 720 w/ SD25 in a junkyard, so I'm back where I started.
For motorheads, I did get a breakdown of where the sensor fit. Looks like it reads the cam gear, which I suppose has an inset on it. If anyone has one of these trucks, you have a jewel of high interest!
The full part No. for the revolution sensor is 25068-54W01.
