CL (Seattle): 1981 720 diesel, $700
http://seattle.craigslist.org/kit/car/283287467.html
DATSUN / NISSAN 720 pickup DIESEL - $700
Reply to: sale-283287467@craigslist.org
Date: 2007-02-23, 6:33AM PST
1981 NISSAN / DATSUN 720 DIESEL
Let’s face it, you are looking at this ad because you like Diesels, or you like old Datsun pickups.
This is a 1981 Datsun / Nissan 720 pickup, King Cab, 2wd, manual 5 speed transmission, and did I say it has the SD22 DIESEL engine.
The good:
• Mechanically, this is in really good shape despite its age and the fact that it was obviously been used a lot.
• The engine runs very well. It emits white smoke (unburned fuel) when it starts cold, but after a few minutes and has warmed up, it emits no smoke at all. It could probably do well with some new glow plugs, but it starts without any trouble at all.
• It has a new alternator and new battery.
• The brakes are in good shape. It has a relatively new master cylinder.
• Clutch is good, also with a relatively new cylinder.
• The rear suspension has Hellwig type overload springs, as well as air adjustable shocks. In all the pictures shown, the air pressure was set at about 80PSI.
• All the glass is intact, no cracks or dings whatsoever. The skylight seal had rotted away, so I sealed it shut with marine grade sealant.
• It has a draw-tight type tow hitch.
The bad:
• Well, just look at it. The body is basically rusting away around the frame and engine. It is an old, beat up truck.
• You can see through sections of the floor and bed.
• The heater / defogger blower is not working.
• The front end is somewhat loose.
This could be a lot of things to a lot of people, for you Bio-Diesel people, this could be the perfect grease collection vehicle (why make a mess in your nice Jetta?). It could be just a parts vehicle, a project vehicle, or it could serve as a perfect base vehicle for your Burning Man art car.
Please see more pictures here:
http://picasaweb.google.com/jhumph/DATS ... SD22DIESEL
$700 OBO
Call or e-mail
Jay 360-621-4866
jhumph@gmail.com
* This item has been posted by-owner.
Image Image Image Image
Bremerton is about one hour from me.
He's running the ad again, with a link to us :)
Nissan / Datsun 720 DIESEL - $700
Reply to: sale-285989831@craigslist.org
Date: 2007-02-28, 7:00AM PST
The good:
• The engine runs very well. It emits white smoke (unburned fuel) when it starts cold, but after a few minutes and has warmed up, it emits no smoke at all. It could probably do well with some new glow plugs, but it starts without any trouble at all, even in freezing cold weather.
The bad:
• You can see through sections of the floor and bed. It is especially bad in the passenger side floor.
• The front end is somewhat loose. There is excessive backlash in the steering gear. It needs to be adjusted. All the steering linkage bushings are OK,though.
The previous owner removed the DPC. It has a cable actuated shut off installed. See this link for a description of the DPC: http://nissandiesel.dyndns.org/viewtopic.php?t=125
$700 OBO
Call or e-mail
Jay 360-621-4866
jhumph@gmail.com
Users browsing this forum: Bing [Bot] and 14 guests
