Alarm Lock Trilogy Narrow Stile Exit Trim + Schlage FSIC tips
Alarm Lock DL1200, DL1300, PDL1300 and variants are narrow-stile exit device combo locks typically used on Storefront doors. There are a few notes I want to keep on these, as I install/service them so infrequently that I forget.
As the override cylinder is difficult to R&R to rekey, I always install these with an IC housing.
Three things to keep in mind on this model:
  • The override cylinder (or IC housing) requires a special cam. For Schlage FSIC mortise housing, use HW1350. Order it separately.
    • The depth to which the IC housing is installed in the front chassis is fussier than usual. I found 0.400" to be a sweet spot.
  • The tailpiece, which interfaces the lock to the exit device, does not come with the lock. Order it separately, specifying the tailpiece that's designed to mate with your exit device.
Shown: DL1300.
Alarm Lock DL1300
Alarm Lock DL1300
Alarm Lock DL1300
Alarm Lock DL1300
Alarm Lock DL1300
Alarm Lock DL1300
Alarm Lock DL1300, backplate removed
Alarm Lock DL1300, cam & actuator
Side view of ell actuator, showing allowable cam contact area.
Install the mortise cyl. or IC housing to a depth of 0.400" as shown below. If installed deeper, then when the cam swings it will run into the thin side of the ell actuator and bind, instead of moving the actuator.
Measuring the mortise cyl. installation depth via dial caliper
Align spindle driver on backplate to "vertical" before assembly.
Tip: if the backplate won't mate fully with chassis, maybe your mortise cyl. is installed too deep.
Mortise cyl. face view w/spacer collar
About DL1200/DL1300 cams
https://tech.napcosecurity.com/index.php/faq/details/id/949/?brand_id=2&faq_category_id=30
Alarm Lock DL1300 mortise cyl. cams info
Alarm Lock DL1300 mortise cyl. cams HW1350 for Schlage FSIC only
About DL1200/DL1300 tailpieces ("spindles")
Alarm Lock DL1200/DL1300 tailpieces chart
Alarm Lock DL1200/DL1300 tailpieces chart w/dimensions
DL1300_Tailpieces-Q08_FAQ_AlarmLock Narrow Style Tail Ima_01.jpg (287.01 KiB) Viewed 112183 times
The documentation only shows the above tailpiece selection, with the TP-1691 being the longest offered, at 1-15/16".
But! The Extended Spindle Kit S6146 for the ETDL/ETPDL product fits the DL1200/DL1300 series as well, and it's a lot longer.
Extended Spindle Kit S6146 spindle, compared to the TP-1691.
There are even longer spindles available for very odd situations:
Extended Spindle Kits S614x
Users browsing this forum: No registered users and 51 guests
