Thanks for the congrats to by the way Rufus, am tired and missed that in my first reading of your post. thanks also for the conversions.rlaggren wrote:250 C. = 450 F.
400 C. = 720 F.
450 C. = 800 F.
550 C. = 990 F.
Congrats. Thanks for the great pics.
How'd you locate the spot to drill (from the outside). Any particular tricks? If you used measures, maybe you could post a list or pic of your working sketch - give the next guy a reality check.
Cheers, Rufus
I'll just edit the figures you put up to include actual readings of the water temperature now I did the same drive again.
EGT C _ _ F _ _ _ Water temp (Deg C)
250 C. = 450 F. _ 45
400 C. = 720 F. _ 60
450 C. = 800 F. _ 75
550 C. = 990 F. _ 83ish
To note too was that the reading over various threads had me expecting rapid changes in EGT temps etc. Although the gauge moves quickly up and down in resposne to engine it was not as quick as I expected. This could be for three reasons.
1/ I got the end of the probe too close to the hollow (I doubt it though as I sighted into the chamber when locating the probe).
2/ It is only measuring cylinders 4, 5, 6 and therefore it is not exposed to the full force of the constant flow of EGTs that a probe in all six cylinders would be.
3/ My expectations were wrong and the probe is in the right place and all is good
None the less, am very pleased with the time and money spent putting this in and am looking forward to the next road trip whereby I can better understand what is happening on long hills etc.
Next time I am out on a steady drive I'll note somemore numbers like rpm, etc also.
Phil
