Hi all, does anyboby know the part number for the stop solenoid on the LD28 Diesel Kiki injection pump?
Thanks, Dave.
stop solenoid
Fuel Cut Solenoid, 16870-V2100, US$127 + shipping
You might pull yours (if you have one that's malfunctioning) and replace the o-ring on the end. If it leaks, I think that the engine will not shut off.
That o-ring is Nissan part No. 16872-V0701, but Nismoparts says that's an invalid number. It's probably a std metric size.
If, OTOH, you're suspecting yours is bad because it does not make an audible "click" when 12v is applied, I think I'd look hard at a used solenoid from a vintage VW Rabbit (Golf) or similar. I'd bet that that particular solenoid is interchangeable.
HTH
Thanks Al, I was after the Diesel Kiki number though
Which one of these do you reckon?
http://www.thetoolboxshop.com/0-129-02- ... 3588-p.asp
http://www.thetoolboxshop.com/0-129-05- ... 4484-p.asp
