My "datsun" 720 Sd22 TURBO Drift Project
elboss
#16
Post by elboss »
She have a loooooot of much power! she drift in top speed with 4º gear, with 2 bar pressure... but the headgasket failed.. to bad :( Now i will put reforced headgasket and i hope she lives more time :P
I have a 4 gear, transmition.. anyone know the relation to 5 gear transmition? Thanks a lot!
elboss
#17
Post by elboss »
reforced head gasket
Image[/list]
elboss
#18
Post by elboss »
Next race, 2 September! See the +2Bar boost!
http://youtu.be/1uT5UFzC1bc
elboss
#19
Post by elboss »
elboss
#20
Post by elboss »
see it run, with a reforced head gasket
http://youtu.be/kfEchaVm704
http://youtu.be/8SfaHaDGB7M
elboss
#21
Post by elboss »
Updated photo on 1º post! thanks!
dn29626
#22
Post by dn29626 »
Re-enforced head gasket? Is it for a SD23 or what is it designed for?
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
elboss
#23
Post by elboss »
its custom made.... for sd22 engine
elboss
#24
Post by elboss »
Now i'm building a smaller one :P A replica :)
Drift car, drift tyres :D
Image :D
It's a shame that we've lost so many of your pictures to photo hosting services that don't have a long retention period.
elboss
#26
Post by elboss »
yes :( :( what a shame :(
But i made a new 1º post, with the photos i have ;)
BigRedDog
Re: My "datsun" 720 Sd22 TURBO Drift Project
#27
Post by BigRedDog »
Related topic. Rebuilding a marinized SD22, head gaskets are easy, but head bolts... Where do you source yours. Also if have a preferred head gasket that would be great.
Thanks for any information you can share with me.
Cliff.
#28
My guess is your rebuilding a modified engine that was used in a boat/ship, is this correct?
I have a turbocharged SD25 engine that in stock form put out 71hp, my guess it is putting out closer to 120hp now, as far as I know it has a stock head gasket and stock head bolts as I bought the engine with a backyard turbo on it that was way too big for the engine and it would not build any real boost, it is a SD25 engine though, as far as I know they all came with turbo pistons stock, SD22 engines did not have turbo pistons except possibly the ones in a SD33 engine with a special injection pump made for the turbo version.
I have seen slightly over 20psi boost in the past, but after 7 or 8psi I did not notice more difference in pull from 7psi and 20psi, so I set my turbo to not make more than 10psi, since then it appears to unload at 7psi or 8psi, I did this to make the engine last longer.
I use stock Nissan head gaskets(sandwich type metal gaskets), my engine has been turbocharged for 8 or 9 years now, have not blown a head gasket so far, but I am not beating it like someone who races engines, and I have an EGT gauge, I never let it get above 1400 degrees, and I spend 90+ percent of the time below 1200 degrees, them long uphill pulls at 60mph+ are tough, keeping it under 1200 degrees is a challenge.
Users browsing this forum: Google [Bot] and 3 guests
