kiki injection pump diaphragm DIY replacement?
my dad has what I believe to be a 1984 Datsun pickup and the diaphragm in the injection pump went bad so we had to put the truck down until we can find a cheap or usable replacement since they are rare as hen's teeth. but looking at the bad one i wondered if there would be a way to tear it apart and replace the leather with rubber, or similar flexible material to make it work again. I found a source in Germany that i can get a replacement for $10 but it cost about $70 to get it shipped from Germany do to customs . im assuming its so expensive and rare because the EPA frowns upon it being alive. ive been googling and searching this forum for over a month now and if i missed a post with an answer my bad but i figured id ask and if no strait forward answer id try and make one with the old one anyways. no when talking to me make sure to use dumb terms since im not a diesel engine expert. but i do understand there functions. Thanks ahead of time!
Re: kiki injection pump diaphragm DIY replacement?
What makes you think the diaphragm is bad, did you pull it and see a crack/hole in it?
Did you check the rubber vacuum line going to the injection pump to make sure it is not cracked?
I have 2 boxes with numbers on them, here they are
Zexel 9 421 610 043-753
_____682___________961______The 682 is under the 9 and the 961 is under the 753, both in smaller print, the -753 is also in small print.
1 55020-7920 0102f
The other one is for a Mercedes MW pump which fits a SD22
Flag 81 1382
1 420 503 903
K00410019-1210
This is all I have, I am not sure which numbers are the part numbers, neither box says what the part is on the box.
1 55020-7920 0102f
Flag 81 1382
1 420 503 903
K00410019-1210
the center part of the diaphragm is practically detached from the outer part i can fit three fingers through the hole. hoses are all good and fine. do you have the diaphragm or just the part number because I have the part number list and cross-reference? if you do have an extra what would you want for it? since I know it comes as a whole unit im going to be tearing it apart today and seeing if it is possible to reuse the parts and make a custom form to form some neoprene and make my own diaphragm to reinstal into the original ring and center. i have acess to a lathe mill and many other machine shop tools so in not worried if i have to remake the center pin if i have to drill it out to get the diaphram out. If it comes apart ok i'll try making a trapezoidal press to heat shape the new diaphram and see if i can make one or not. since they are so sparcly found it be good to know if it works or doesn't work.
part numbers for the diaphram are
BOSCH 9 421 610 043
ZEXEL 155020-7920
NISSAN 1922576200
with a diagram of the parts here
https://fuel-inject.com/diaphragm/zexel ... 421610043/
and i could not find a supplier in the us that was a good price.
BOSCH 9 421 610 043
ZEXEL 155020-7920
NISSAN 1922576200
I have 2 brand new diaphragms, but I will not sell them, the boxes are what I got the numbers off of, I have several SD series engines so I collect parts when they are available.
All you need is the diaphragm, every one of these parts I have ever seen just came with what is in my photos below. I have an old used one in an old injection pump I have, I have no idea if it is good or not, below are photos of it. You can see in the photo below that I threaded the hole in the center, I did not drill the hole, I just threaded what was there, I had planned on trying to make the injection pump manually controlled so I could turbocharge it, but I figured out how to turbocharge it without changing anything on the injection pump. I cannot see any holes in this diaphragm, and it is soft(not dry) and appears to move fine, I suppose I would take $30.00 shipped USPS flat rate box to the lower 48 states, I cannot guarantee this part as it is an old used part, all I can say is it is soft and pliable.
Have you tried a diesel injection shop where they rebuild these pumps?
the used one would be too risky. since I plan to daily this truck if I can get it fixed. we tried local shops with no good answer and that's why I went to see if I can form my own. if I succeed it might be a good way to make a little extra cash by repairing broken ones. I managed to get the whole diaphram apart without destroying anything to bad and im going to machine a press form to make a new diaphram out of neoprene or likewise rubber. and see if I can reassemble it well enough to work well.
From a previous discussion, 13 years ago:
If you can rebuild the pneumatic governor diaphragms, you'd have a captive (though shrinking) market.
While they do tear, if proper addition of the diaphragm lubricant is applied regularly, they do seem to last pretty well.
Old discussion about cod liver oil and replacement lubricants for the SDxx pneumatic governor diaphragm.
My old Ranger with the SD-22 transplant is still running the same power steering fluid that I installed in the injection pump 15 years ago. Works fine...
i had fair luck taking the whole assembly apart and if i can get a system for forming a diaphram rubber I should be set for making one. the aluminum ring on the outside was slightly mangled getting it uncrimped so i may have issues using it but if I can get the orientation of the diaphram right i should be able to make a seal without the ring on the outside. possibly using an o ring as a sealing spacer in the recess for the ring.
- 53352584_426841131385992_6288183591402733568_n.jpg (308.56 KiB) Viewed 15392 times
I hope it works out for you.
thats what the technition told me to set it at for the pumps state of tune
is it possible to get the pump 360 out?
thanks
Jeremy
thanks
Jeremy
