There are two phillips head screws, plus two brass looking pins. The pins look like they are tapped in, and I tried to drive them out by tapping with a hammer and screw driver. I don't want to break anything, so can anyone help me out with the secret of removing the ignition switch?
Thanks!
David L.
How do you remove the ignition switch from steering column?
- TruckA
The two others are security bolts. The heads break off when they come up to torque.
You can sometimes use a pointed chisel and catch one side of the head and walk it out that way. If you have room, you can also use a Dremel with a fine wheel and cut a slot into it -- you do end up cutting a slot in the screw's well walls, but that's OK.
I use both methods. The pin chisel method is slightly easier and less messy, but is not 100% effective, esp. if you've bent the screw by pounding on it. You might have to create a slot in the head in your case.
The bolts had heads on them. They are break-away heads. You torque them up, and the head breaks off. That's a common item, actually; many mfgrs use them.
I found a picture (drawing) of the shear head screws before they are installed. See the keys/locks thread.
