How do you remove the ignition switch from steering column?
TruckA
Post by TruckA »
There are two phillips head screws, plus two brass looking pins. The pins look like they are tapped in, and I tried to drive them out by tapping with a hammer and screw driver. I don't want to break anything, so can anyone help me out with the secret of removing the ignition switch?
Thanks!
David L.
The two others are security bolts. The heads break off when they come up to torque.
You can sometimes use a pointed chisel and catch one side of the head and walk it out that way. If you have room, you can also use a Dremel with a fine wheel and cut a slot into it -- you do end up cutting a slot in the screw's well walls, but that's OK.
I use both methods. The pin chisel method is slightly easier and less messy, but is not 100% effective, esp. if you've bent the screw by pounding on it. You might have to create a slot in the head in your case.
TruckA
Post by TruckA »
Thanks for the help, I'll bust out the chisel and dremel to see which one I can get to work for me. How in the world do the screws get torqued in from the factory when they have no head on them?
David
The bolts had heads on them. They are break-away heads. You torque them up, and the head breaks off. That's a common item, actually; many mfgrs use them.
TruckA
Post by TruckA »
I can see how they work now, where the head broke off, it looked like surface marring from if they were driven in. I haven't run across them before until now, thanks for the information.
David
I found a picture (drawing) of the shear head screws before they are installed. See the keys/locks thread.
