LD28 CRANK NEEDED!!!
DMS
Post by DMS »
Im moving in June. I was almost finished installing my LD28 in my 260z when I dropped the #2 rod. I need to be a "crank pirate" but it is to fix my current LD diesel. I have a mid sump engine so it's had to just find another engine and drop it in. I think it's hard enough to find a diesel Maxi as a donor anyway. I have parts to trade: I have 2 other LD heads complete one with an extra set of injectors and a LD28 maxima bare block. I also have Datsun Z, Roadster, and 510 related parts. I will pay cash if local or if you are far away and need to ship let me know how to pay. I have paypal as well. I am moving to a place where the car must run or I cannot have it. That means the car will sit in a field 3 hours away from me for like ever!
My crank needs magna fluxed, trued, ground, re-chromed to STD, and then I can use it.
contact info
I am currently in Hollister Ca 95023
but I am moving to Sacramento Ca by June 7th
Ray
831-402-5387
Someone please help me get my car running?!
Ray
I can't help you with a crank nor a complete engine, but I'm interested in hearing how you "dropped a rod". Is there a story there?
DMS
I suspect...
Post by DMS »
that My engine suffered fatigued rod bolts. I had the pan off before i installed the engine. I checked the torque on them 3 times... with a good torque wrench. I will know more after I get the engine apart. I pulled the head a while ago. The head looks okay. I need to check #2 valves. Im going to get the block machined while Im at this. I pulled the coolant drain plug and it was full of rust. The head surface is in great shape. The hones look okay, but I will take the time to de-glaze them buy some rings if i can find a good set. Im going to get some bearings as well. I have a lead on a Fel-Pro head gasket... The one that is off the selves and out of production... Found it on a shelf for $80. The intake and exhaust gasket is the one I cant find so i left them on the head.
Ray
Ray
Crank on Craigslist
I came across this on Craigslist:
http://sfbay.craigslist.org/sby/pts/691262581.html
LD28 diesel crank shaft - $330 (san jose east)
Reply to: sale-691262581@craigslist.org
Date: 2008-05-22, 3:02PM PDT
I have a ld28 crankshaft from maxima die sel engine that I have bought from my friend a while ago. Now I need to finish up my project so this crank need to go. For those that is interest give me a call to come and check it out 408-410-8995. It look in good shape, but a little dirty and need a little cleaning.
That's approximately what they go for on eBay.
Re: I suspect...
DMS wrote:The intake and exhaust gasket is the one I cant find so i left them on the head.
Did you see this one?
Also, you may be interested in gaskets I have available to sell.
legacyelectric
Crank found
Post by legacyelectric »
Hello
I may have a crank for you. :D Let me do some more checking on it
Larry
All for sale
982 nissan 5 spd ld28 diesel Maxima sedan just got a new oem tranny installed runs great
1983 wagon ld28 with a 5 spd tranny just put in a new (junk yard) rear-end. runs great also
1982 mercedes 300d
1997 6.5 td 1 ton
1992 6.5 td 3/4 ton
too many others to mention
legacyelectric
I have one
I've done the checking and I have a crank if you want one
Larry
All for sale
1982 mercedes 300d
1997 6.5 td 1 ton
1992 6.5 td 3/4 ton
