SD22 IP mounting: inner bolts
biodatsun
Post by biodatsun »
Can some please post pictures of the tool setup that could be used to get the inner bolts loose. I would like to adjust my timing but can't seem to get on these so I would like to see what works so I can buy the right items.
T McLeay
1-1982 Diesel 720
1- 1998 Subaru Forester
1- 2002 Dodge cummins 4x4
Assuming the Inline IP and not the rotary IP (see this post for pictures of both): I think I've been using 1/4" drive deep socket, a "wobbly" (1/4" u-joint) and various length extensions. But that's just from memory at the JY a few months back.
biodatsun
Post by biodatsun »
My apologies about neglecting to mention it is an in-line pump. Thank you Al I will have to add to my 1/4 inch socket set.
T McLeay
1-1982 Diesel 720
Users browsing this forum: Semrush [Bot] and 1 guest
