Consuming 4 liters oil per 600km!
after oil
thanks kevin
i guess where i am at then is to take off the manifold and get a better look...
After replacing all the valve guide oil seals ... what is the new distance per oil quart?TDI_Joe wrote: _SNIP_ These injectors were rebuilt 4,000 miles ago. Note number 2 has much oil residue. Oil use was about 1qt per 1000 miles.
Was there any other "fixes" when you had these seal replaced?
- TDI_Joe
Philip, I am still assembling the engine. I am doing the bearings and syncros on my transmission as well. I will post pictures and data on my "project" when the finish line gets closer. I am also going to repaint the truck while I have most of the running gear out. Oh yes did I mention I am also rebuilding the front end, new control arm bushings top and bottom, ball joints, tie rods etc. Shouldn't be bored for a whilePhilip wrote:
No Worries Mate.
-Kevin
92 Honda 1500 GW SE 30K
82 Datsun 720 KC SD22 228K
-Kevin
after oil
i took off the manifold yesterday. i wont bother uploading the photos yet b/c my computer is screwin up and freezing again.
but what i saw was:
intake manifold a little oily and gritty.
exhaust:
cylinder 1, inside the head has a smear of oil that follows a path, its not all over the inside. this is the cylinder suspected of having worn oil ring
cyls 2 and 3 seem to be weeping oil at the valve seals, just a few drops on the valve stems. cyl 4 is clean and dry.
all cyls are otherwise dry and sooty
but what i saw was:
exhaust:
after oil
please accept my apoligies for "bumping" this post. i hope someone will notice now and give me some ideas about the oil inside the head coming from the exhaust valve of cyl 1, and the weeping oil around the exhaust valve stem seals in cyl 2 and 3.
and im having a hell of a time getting pistons and rings! anyone in winnipeg? http://www.pistonringservice.com/ has the parts, but wont sell them to me!! they said i could come down to the store and get them...
store locations
store locations
Al has put to you ....
Al's observation ...
"The reason this idea is so attractive is that it corresponds with the both the symptoms and the timeframe: reasonable oil consumption before taking off the head, unreasonable after. And Paul didn't do the head work so he doesn't know for certain what transpired or how it was assembled. Which is why I've asked three times to look at the valve stem seals: not because valve stem seals are a real likely candidate for that much oil consumption, but because it's possible and it fits the whole scenario, unlike the other guesses."
after oil
i posted the best photos i could of the valve springs. i could try to remove some springs, but i havent got the tools.
i brought the head to someone who has the tools and can inspect the seals for us!
Do look at how THESE oil seals must be installed for SD22's.after oil wrote:i posted the best photos i could of the valve springs. i could try to remove some springs, but i havent got the tools.
It is quite possible to rip the seal lips yet ... the seal "looks" install and good.
after oil
thanks philip
paul at piston rings services really helped me alot!
he figured out a way to get my money and ship rings!
and reed's machine shop near bellingham WA is bringing a piston from his supplier in ohio. im going to b-ham next week, so i lucked out there. they figure itll be less than $100 after shipping
after oil
and finally the photos:
CYL 1 NOTE SPRAY OF OIL INSIDE PORT
CYL 2 (3 LOOKS VERY SIMILIAR, NOTHE THE OIL WEEPING AROUND THE SEAL
Ok. It is clear that:after oil wrote:thanks philip
he figured out a way to get my money and ship rings! -snip-
1) you won't say another word about oil seals
2) you believe something awful happened recent that toasted pistons and/or rings.
(followup): The ROUND ports are the EXHAUST ... which I don't care much about. The OVAL ports are the INTAKE ... which I do care about.
SO .... you have one useful photo ... the one of the entire head sitting on a wood bench ... with sunlight. Could you photo that one again but this time ... from a slightly higher view or .... from the opposite side? I'm looking for a view that includes where the springs meet the cylinder head.
Thank you, in advance.
after oil
i dont know what to say! the head is at a mechanics and he is inspecting it more closely.philip wrote:1) you won't say another word about oil seals
again a case of mechanics' differing opinions! maybe i wont need the rings and piston, but considering the hardship getting them, at least i have them if i or anyone else around here needs them.you believe something awful happened recent that toasted pistons and/or rings
DARN! i thought all along the exhaust had the clues, but i guess after thinking a little about it the oil in the exhaust must be blowing by, not combusting (DUH)!
there hasnt been much sunlight here the last few days, and the head is in the shop for inpsection, but as soon as i know more you can bet i will post it
Or ....after oil wrote:philip wrote:The ROUND ports are the EXHAUST ... which I don't care much about. The OVAL ports are the INTAKE ... which I do care about
DARN! I thought all along the exhaust had the clues, but I guess after thinking a little about it the oil in the exhaust must be blowing by, not combusting (DUH)!
There hasnt been much sunlight here the last few days, and the head is in the shop for inspection, but as soon as I know more you can bet I will post it
"Somebody please ... just SLAP ME !"
(1994)Al and I have always agreed that valve stem seals must be reviewed first because ... your oil consumption was NOT a problem until after your cylinder head was worked on.
Seals first. And then only if found sound .... the rings.
after oil
the guy finally looked at the head and said the seals are fine! he said that he could see lots of oil in the valves of 2 and 3, indicating blowby becuase of excessive compression. that the compression was getting higher as it went back becuase of the blowby from the worn ring in cyl 1, or something like that.
the rings arrived, $135 for the rings, $30 to rush them on the bus. i picked up the piston in bellingham, it was $80 including the shipping from ohio.
my computer is topsy turvy lately, lost of freeze ups, viruses getting in etc!! and ive been busy with other things.
im going on a week long mountaineering adventure in the coast mountains so aint nothin gonna happen with the truck till after that.
Having just followed my own advise, I found that I'd missed a step.
asavage wrote:Off the top of my head, you might consider . . .
- Make up an adapter for my GP adapter
to connect shop air to it.
- Remove Schrader valve from the tip of the GP adapter.
- Bring a cylinder up to TDC, valves closed. Exact TDC is required.
- Remove oil filter.
- Use shop compressed air, pressurize cylinder to max shop air pressure (100 PSI or better).
