LD20T-II valve settings
inniss
Post by inniss »
Hi folks
An new to diesel engines and just trying to keep an old vehicle functioning.
can anyone tell me what is the vlave clearance for the LD20T-II preferablly cold?
Samuel
LD20T-II in old ISUZU VAN
engine warm.lock nut 36-43f/lb
IN
0.010 [0.25mm]
Ex
0.012[0.30mm]
inniss
Post by inniss »
Thanks.
I found it difficult to move these nuts, any suggestions? They appear to be 12 and 14 mm nuts, is this correct.
My other problem is that the engine is smoking too much when under pressure like going up hill and just after moving off. Any suggestions?
The person who set it up for me did not connect andy of the wires on the fuel injector. Could this be the reason for the smoking?
any idea where these wires should be connected?
Samuel
there are no wires conected to injectors.
4 glow plugs--screw into the head near the injectors to preheat before starting.these are looped together and run 12 volt for a few seconds.
these will run 7 volt for a longer time.
Injector Pump.
you only need the single wire on the rear of the pump that turns on the fuel.throttle position is not used.
there is a cold start solinoid on the fuel return pipe on cold climate cars.
from memory putting power to this shuts off the fuel return causing rich mixture.
davehoos wrote:there is a cold start solinoid on the fuel return pipe on cold climate cars.
Surely not. Perhaps you meant "advanced timing"? This is the way the EGR/throttle position sensor/intake butterfly system works on the LD28: when the EGR system is active in Stage II or Stage III, the IP timing is advanced during EGR operation to improve driveability.
inniss
Post by inniss »
Thanks guys but I still have the problem of black smoke at times.
How can I remedy this?
I don't know. My LD28 has been a heavy smoker all its life. Cleaning the intake didn't really help. B100 improves, but does not eliminate the problem.
On the LD28s that smoke, I've come to believe that the internal advancer no longer functions on most of them, the timing remains more or less static, and that's the cause of the smoke on the ones I've had through my hands. Just a guess, but an educated guess.
Fix: rebuild the IP.
LD20 have the timing lever on the side-water or ischoke cable operated.
same as USA LD28 this also contacts the fast idle.
some other brands of engines have a mechanical mechanism refered to as retarder.
retarded timing can often asist with starting and quick warm up,EGR gasses are also a defacto retarder.---that said advanced timing gives a hot burn and improoves idle due to extra burn time and im guessing the retard control is to counter a fully advance system caused by other devices.
one device to counter another..
2 some cold area nissan feed the return line back to the pump or filter untill the fuel warms up from heat within the pump to reduce waxing.temp control can be electrical or thermol.
3 cold start electrical shut off solinoid is part of the return outlet banjo.
this increases the pressure inside the pump.so from my understanding this would slide the advance piston to the max poition as it is controlled by fuel delivery pressure that is now at maximum.some problem occures when an electric fuel pump is used.
asavage wrote:I don't know. i also dont
On the LD28s LD20that smoke, I've come to believe that the internal advancer no longer functions on most of them, the timing remains more or less static, and that's the cause of the smoke on the ones I've had through my hands. Just a guess, but an educated guess.
most of the JAP import engines here have the black smoke tail.
this also occured with rare batches of brand new vehicles.TD27 is aa classic as the van and some D21 models have problems.officially i was unable to find a cause but its stange when the new ip is sent to have the calibration tested or a pump was swaped from another engine it cures the bad habbits.
the used engines ive owned I added petrol,kero or some other additive in colder weather[mild australian winters] this is due to the poor quality of local sold diesel compared to japanese domestic soudi deisel.
davehoos wrote:cold start electrical shut off solinoid is part of the return outlet banjo. this increases the pressure inside the pump.so from my understanding this would slide the advance piston to the max poition as it is controlled by fuel delivery pressure that is now at maximum.
Yes. Timing is advanced, not increased fuel volume.
Because an external fuel pump cannot make the internal housing pressure (which can top 100 PSI) to work correctly. If there is a housing pressurization issue (worn/pitted lift pump, etc.), adding an external fuel pump will not work correctly.
