How much vacuum should the vacuum pump suck.
asdex
Hi at idle my pump sucks at about -3.13psi and when I rev the motor it goes to -3.84psi. This is with a digital gauge and measured by taking off the small hose to the auto transmission and measuring at the back of the pump.
Does this sound correct?
Thanks
Thanks
I think vacuum (in the US anyway) is measured in inches of water. As I recall 16-20 inches is normal for a gasser (as measured with a common gas pump/vacuum tester gauge available over here) and I suspect that Nissan did not modify it's vacuum controls just for the diesel so the vac pump output s/b similar. If you go to a online conversion site you can probably get the value in various other units.
windsock
G'day asdex,
I assume we are discussing the vacuum pump at the rear of the alternator?
If so, converting your psi scoreto inHg (inches of mecury) or inH2O (inches of water) we get 6.37-7.82 inHg or 86.6-106.3 inH2O.
I have just connected my vacuum gauge to the vacuum pump and it was off the scale so my one pulls more than 25 inHg or 700 mmHg. Inches of mercury or water is the most common notation of vacuum I know of.
Your one seems a tad low by comparison.
Hope this helps.
Cheers,
Phil
Hope this helps.
Cheers,
Phil
asdex
Vaccum
Thanks very much for those answers.
I think I will look into it a bit further because as the automatic works off vacuum a low reading may make it change gear later which seems to be the case. I feel it should be changing sooner after I start off.
I have just had the brake booster reconditioned so it should have a good seal.
Cheers,
asdex
Cheers,
asdex
windsock
Hi asdex,
When you say you feel the gearbox should be changing earlier, what sort of rpm is it changing you think? These things redline and are limited at 5400rpm. In my 2000kg land rover 5-speed manual my changes go something like (rpm range is mood driven) - 1st-2nd=1250-2500rpm, 2nd-3rd=1250-3000rpm, 3rd-4th=2500-3800rpm, 4th-5th=3000rpm. Max torque is about 2400rpm. Our vehicles most likely have the same aerodynamic profiles...
If it is still needing to be checked and stating the obvious, I'd check each tube coming off it for seal. If that doesn't fix things, I'd check the oil supply to make sure it is delivering sufficient oil to keep the cogs in the pump lubed and sealed for vacuum. There is also a large o-ring between the body of the pump and the body of the alternator, check this but I am thinking if this is leaking you'd see the oil leak. I have a pump that has several elbows off it from a car and I replaced all the copper washers on mine a while ago to make sure of a good seal.
Hope you can fix it easy. It is a messy business mucking about with the pump down there with all the oil and angles. If you remove it in-stiu watch out for cog movement within the pump, it can be a real bother to get the splines all lined up again to reinstall.
I noticed a couple of alternators for sale down in Invercargill on Trademe - ~$125 I think so quite pricey.
Phil
Phil
Don't recall if you have an FSM. There _may_ be a vacuum regulator in the circuit. IAC, it may be worth the $50 odd USD to get a hand vacuum pump w/gauge so you can apply vacuum to your system at various points and see whether you have a seal; might find it cheaper online. Applying it to the hose (disconnected) from the pump would test the whole system. The hand pump is useful for various other stuff also - see many of Al's posts about the Mighty-Vac.
Here you go:
Automatic Transmission problem 82 wagon
http://nissandiesel.dyndns.org/viewtopic.php?p=780#780
You're welcome.
You're welcome.
asdex
Sucking
Hi, thanks for the info. I have a manual so will check that.
The engine has a rev sensor so I'll look out for a rev counter too.
I saw those alternators and that could be an option later once I've done the tests and checks you suggest.
$125 isn't too bad I just had to buy a rebuild one for my Toyota Corona 2c diesel which cost $580.
Cheers,
asdex
Cheers,
asdex
windsock
Hi asdex,
Maybe drop by a couple of nissan wreckers and ask if they have a C32 Laurel car with intact dash. You can get the tacho out of that and wire it in to the rev sensor behind the IP front mount housing. Tacho to go...
Just a correction from an earlier post I made. These redline at 5000rpm not the 5400 I errantly stated. I looked at mine on the way to work today and realised the error of my ways... still nice to hear the roar well up to 4000 from a diesel.
cheers,
Phil
cheers,
Phil
asdex
I have my vacuum gauge on and going now. It reads 6"Hg. I'm not sure how the chart for this works though. I see at 700 rpm it chart says 23.62"HG and at 5000rpm it shows 7.87"Hg.
I though the faster the vacuum pump would spin the higher the vacuum that would be created. I will test now by closing off thew various hoses to check for leaks before looking at another alternator.
Thanks
Link to chart.
Thanks
Link to chart.
nogrip
my 4 speed auto seems to change up quite late also..
i dont think theres an issue with it,
kick down seems to be quite quick when required..
maybe its just changing late due to more load being needed to haul the transit...?? thats the conclusion ive come to on my transit anyway...
ld28t in a 81 transit van
asdex
Yes that might be so. If I find the vacuum is ok at that amount, I'll leave it at that. I guess there should be some sort of regulator to keep the vacuum constant but I don't see one. My kickdown and overdrive are switches on the dash. I was told the van has a Zephyr diff to which helps with gearing.
I will also keep an eye out for a rev counter but don't want to spend to much untill I take the van for some long trips over Christmas. Engine and auto are in an unknown state although the oil pressure runs about 60psi which sounds good. Cold it was 80psi.
Thanks
Thanks
nogrip
asdex wrote:Finally figured out vacuum. My gauge will be 29 inches of mercury at zero with the motor off. Thats normal air pressure. When I start the motor it goes to 6 inches of mercury. So it's increased the vacuum from 29 to 6 which is good for the vacuum pump.
Cheers
