nissan sd 16 diesel
RichardH
nissan sd 16 diesel
I have a nissan diesel sd16 generator. I cannot seem to find any information on this motor. Can anybody help point me in the right direction?
It's in my race car trailer that I just bought. The guy said it has been sitting for a few years. It sounds like it wants to crank over but will not start. I think the glow plugs might be faulty. But here agian, not sure.
Is there some kind of repair manual for this or what?
Any info will help.
Thanks, Richard
Any info will help.
Thanks, Richard
Cmdr. Ron
SD16 Gen Set
Greetings!
Did you find any data on your "new" SD16?
No, sadly, I have none to offer. . . hoping you found what you needed, want to hear about the engine & basics on generator.
Cmdr. Ron
Cmdr. Ron
'82 DATSUN 720 SD22, '77 Fiat 124 Spider, '81 Toyota HiLux, '64 Chevy Corvair Monza
The Blessing of Abraham is mine!
There was an auction a couple of years back, and the online photos of various engines did show an SD16. As I recall, it was a 3-cylinder variant of the SD.
[later edit] Here's the link to that discussion.
[later edit] This web page lists the SD15 & SD16 as 3-cyl. engines.
Other than that, I have no info, but I bet that most of the "normal" SD22 info applies to the SD16, with the exception of the IP.
The SD has a lot of variants.
In agricultural, marine, and genset use, these engines' ancilliary systems are often customized, especially governors, start/stop, and glow plug control. If you can't find the *exact* manual(s) for the genset, you'll have to do like the rest of us: apply basic priniciples and muddle along as best you can.
charmalu
Contact Jesco, they might have the info on the engine.
Gary Machado 209-537-5057.
Charlie
Charlie
78 240D Mercedes $300 Parts?
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
86 Ford F250 6.9 Diesel 221K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
Jesco are the folks who were auctioning off the SD16 above.
charmalu
I read through the above links to the other thread on the auctions from a couple years back. I didn`t pick up any real info explaining about the engine. except it was used for a gen set etc...
Maybe I mis read what he was asking for. I assumed he was looking for a FSM on the engine. Jesco being a distributor on the Nissan Diesel eng. should have it I would presume.
I understand Jesco was auctioning off the engines. wish I knew about it then.
Charlie
Charlie
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
80 240D 360K
80 240D Parts? $750
82 240D Parts? $440
84 300SD 270K
85 300D 363K
Liam
SD16 manual
Richard,
Did you ever find a manual for the SD16? I am just rebuilding one and looking for a manual myself.
Users browsing this forum: No registered users and 34 guests
