exhaust manifolds
pidder
exhaust manifolds
was wondering if the sd22 and sd25 exhaust manifolds are interchangeable? I have a sd22 in my suzuki samurai and can get an exhaust manifold from a sd25 to start mocking up my turbo build. But want to be sure before I start, otherwise will have to remove my manifold from my daily driver to do the work. Thanks.
There's really not a lot of folks in the US who have experience with the SD23/5. Not a lot of them around. Quite a few more in Canada, but I'm not surprised that we don't have an SD guru here who knows the interchange on manifolds.
pidder
greyfoxxca
turbo
I take it that the sd 25 and sd22 have the same exhaust manifolds?
What did you use for a turbo? I have a turbo from the turbo charged Mitsubishi 85 ranger . I was going to try this one. Did you do the welding on the cast iron?
thanks
George
thanks
George
pidder
Yes the manifolds were the same. I kept my original one intact in case the turbo install didn't work out. Because I have the sd22 in a suzuki samurai the space was very limited. I cut off the flange where the exhaust used to exit and capped it. I then used a 1.5 inch hole saw to open up the center of the manifold. I then came up andout with a piece of1.5 sched. 40 pipe and used two 90 degree weldells to put my mounting flange where it needed to be. My problem was trying to make the exhaust cleaar my steering column. Welding up my exhaust pipe was fun with about 6 mitred joints to make the bends to miss my steering column, the frame and the motor. I used a mitsubishi turbo from a 97 plymouth colt with a 1.6 litre motor. i did all the welding on the manifold with nickel rods.
pidder
exhaust manifolds
http://www.lj10.com/forums/viewtopic.php?f=18&t=5582 here's a link to some info and pics I posted on lj10.com a suzuki forum. hope it helps. Norm
