Weight of LD28
Weight of LD28
Does anyone know what an LD28 complete sans alternator weighs?
Ballpark figure.
No trans, just engine.
Ballpark figure.
Ben Martin
Re: Weight of LD28
Don't know for sure, but my guess is 500 lbs.83_maxima wrote:Does anyone know what an LD28 complete sans alternator weighs?
Ballpark figure.
steve
My guess is 450 lbs.
http://www.jescoweb.com/LD28.htm [edit 15May2013: bad link] 'Course they also claim it has an "inline plunger" IP.
That's it!
My guess was a lot more. The L28Es that I have pulled and moved were quite heavy, though I never weighed them, and figured the LD28 being all cast would be a lot more.
That is good to know. Thx.
Ben Martin
Wow...that's lighter than I expected for an all-cast iron 6 cylinder motor! IIRC the peugeot 4 cyl. alloy head motor I had sent from Seattle a few years back weighed in over 450. It had a turbo too, so that's extra weight I didn't consider.asavage wrote:My guess is 450 lbs.
http://www.jescoweb.com/LD28.htm [edit 15May2013: bad link] Jesco says 415 lbs. 'Course they also claim it has an "inline plunger" IP.
What did that cost you Steve?glenlloyd wrote:Wow...that's lighter than I expected for an all-cast iron 6 cylinder motor! IIRC the peugeot 4 cyl. alloy head motor I had sent from Seattle a few years back weighed in over 450. It had a turbo too, so that's extra weight I didn't consider.asavage wrote:My guess is 450 lbs.
I'm thinking of having an LD28 shipped from CA to CO.
Ben Martin
Another reason I am suspicious of Jesco's number is that they say that the http://www.jescoweb.com/SD22.htm] [edit 15May2013: bad link] SD22 weighs 474 lbs! Making the 61 HP Four weigh more than the 80 HP Six.
I think it was $163 but I'd have to look at the receipt to be sure. It wasn't expensive but then again fuel was cheaper back then. Also, the salvage yard setup the transport so I received their reduced rate freight cost.83_maxima wrote:What did that cost you Steve?
Steve A
Users browsing this forum: Google [Bot] and 32 guests
