Lot of power on SD22
Dale
#16
Post by Dale »
The diagram is rotated 180 degrees vs the picture, they are both correct.
dn29626
#17
Post by dn29626 »
Thanks for the confirmation.
82 King Cab 2wd (nice)
82 Reg Cab (body damage)
Anderson , SC
Since Fall 2009
fieldtech
#18
Post by fieldtech »
Ambon the process of turboing two sd22 engines. the turbo you
have does it boost good at low engine rpms?
two 1982 720 diesel pickups- 200 numbers apart in the vin. one has 438k- runs great- pulled engine to put in a Sami. other 720 has 161k. turboing both!!
elboss
#19
Post by elboss »
yes you can see in video, i dont have rpm's, but maybe 1 or 2 seconds lag...
You can see it running in last sunday NOV, with a new reforced headgasket...
http://youtu.be/8SfaHaDGB7M
http://youtu.be/kfEchaVm704
elboss
#20
Post by elboss »
I just want to say, the engine still alive!!! with About 8 hours running, oil temp - perfect, Headgasket - perfect! water - perfect! :D :D :D :D :D
Maybe tommorrow i add one video!
rhino 660
#21
Post by rhino 660 »
can you take another picture of your throttle setup and of your turbo setup
im in the process of removing the diaphragm fuel controll and am switching to your setup thanks boss
elboss
#22
Post by elboss »
One more race, and she still alive! Run very very well!! see this!
http://youtu.be/7MPEuME3pJQ
http://youtu.be/ZOAjUU_HcRk
elboss
#23
Post by elboss »
Hi buddy's! My engine still alive! the headgasket is good, the engine still sound very good! check in this video, the sound and the power of this engine ;) http://youtu.be/qbGJCtBFZ3E :D :D :D
dn29626
#24
Post by dn29626 »
What date did you install this current head gasket?
Please repeat the info on this good gasket, source, part number, any related info.
Anderson , SC
Since Fall 2009
elboss
#25
Post by elboss »
in december... i made 5 races, full day running, with 2 bar... the head gasket is "home made" by "Euro juntas" in portugal
Please repair the broken picture links in your posts at the beginning of this thread.
elboss
#27
Post by elboss »
i think its done :) sorry!
There are still broken picture links in
this post
and
this post
and
this one
elboss
#29
Post by elboss »
i dont know what photo is :/
Now i work to change the inline pump, to a zexel pump:
and maybe the next bi-turbo:
elboss wrote:i dont know what photo is :/
Please do not post pictures that will only be viewable for less than twelve months.
