Nissan sd25 rebuild
Jud0228
Nissan sd25 rebuild
Post by Jud0228 »
I have an old sd 25 that i am going to be rebuilding for a convertion. I found a rebuild kit on ebay but it says it is for fork trucks. Does anyone know what the difference would be or does anyone know of a better way to find a rebuild kit for this motor?
http://item.mobileweb.ebay.ca/viewitem? ... 0299897488
Thanks in advance.
I can see no difference in the two engines.
The biggest difference would be in how the accessories fit on.
Exhaust manifold will be different and the starter ( perhaps ) , and perhaps even how the alternator or intake fits on but strip all those off and it would be the same.
You will have to pull your old crank and get it measured so you know what size of brgs/thrust washers to order
That is actually a not bad price for that kit.
IMO that is
Jud0228
Post by Jud0228 »
Thanks paul. I guess ill get it stripped down and get some measurments. But befor i start i also havd an sd 22, i was told the 22's were bulit proof and the 25's were good becauae they had more power, is that correct?
Yes they are a pretty good motor. The 25's have a more robust bottom end as the 22's only had 3 mains and the 25's have 5. Other than that they were pretty much the same. They have different fuel pumps as the 25's in the Canadian version of the D21 has the VE style with the CSD etc. and the 22's and 25's in the 720's had the inline.
Jud0228
Post by Jud0228 »
Ok thanks alot for the help!
The agricultural/forklift/marine versions of SDs often seem to have five-ring pistons, vs the three-ring version in automotive trim. Not that that makes a heckuva difference, but it bears noting.
See this thread for more info.
^^^^ Agreed,
Forgot about that part.
