Server Blog
Moderator: Nissan_Ranger
- Been thanked: 6 times
Re: Server Blog
Not you isp. It takes a long time to load for me too.
Some days....bam! ! ! It's there !!
other days zzzzzz
I
other days zzzzzz
I
Re: Server Blog
It was painfully slow this morning. Restarting MySQL didn't help, which has been the usual fix in the past. I tried to restart the Apache service, and the service hung, so that was it. Rebooted the entire box, and now it's speedy again.
I think I tried to automate restarting Apache before and was unsuccessful at a 100% reliable restart. Maybe I'll look at that again after work today.
Re: Server Blog
Indeed it is speedy
Thanks again Al
Pretty early start for you. 0430 on a Sunday morning.
Thanks again Al
Re: Server Blog
These days, I'm up at 3:40am five days a week, and Sunday is one of them.
Re: Server Blog
It is very fast now, came right up without any waiting, thankyou AL!!!!
Re: Server Blog
I've implemented a kill/restart process for the web server (httpd) that will kill off the service at 0001 (a minute after midnight) every night, and restart it. The database (mysqld) has been set up this way for a couple of years, at 0002 daily. Let's see if restarting httpd every night helps with the occasional slow page loads we've seen.
Re: Server Blog
Fast this morning at 0620 to log on AL.
Navigating around once inside seemed to take a bit of time. Switching from one topic to the other takes a while to open.
Not sure if its site issue or ISP issue at my end.
Just for an FYI
Just for an FYI
Re: Server Blog
Inadequate testing: the script to kill httpd would run from a CLI but not from cron -- fixed (I hope).
Re: Server Blog
Not sure of what you refer to above but I know it's nice and speedy to log on and navigate around this morning at 0750
Re: Server Blog
I haven't been able to reproduce that here. I've tried several times over several days.plenzen wrote:Navigating around once inside seemed to take a bit of time. Switching from one topic to the other takes a while to open.
If you find this happening again, would you PM me with links to a representative topic -- one that's slow to load?
Re: Server Blog
It's a lot better now, when before it took 5 minutes to load a page, it now takes 2 seconds, it's great!
Thankyou very much Al!!!
Failed reboot 05Dec2014
On 05Dec, 2014 the server failed to complete a maintenance reboot, ten minutes before I had to leave to catch a flight out of the country.
It failed in a non-intuitive way and required a bit of research and consultation to determine the best course of repair, and I accomplished those while away. I was able to repair the problem (corrupt OS2.INI or corrupt OS2SYS.INI) by using backup copies.
The forum's data was never in danger.
Re: Server Blog
Thanks for fixing and getting us going again Al
Re: Server Blog
It's back to normal again Al, thankyou again.
