EGR and Throttle Body Delete
nissan_nerd
Been thanked: 1 time
Post by nissan_nerd »
I hope this forum is still active after all these years. I recently got my hands on a 1982 Maxima Diesel as a California smog exempt project I can throw any motor into. However, my LD28 is still going strong and I plan to keep it in the car as long as possible. I would hate to see a perfectly good LD go to waste for a 3.1 hack job.
Popped the intake off to clean the NASTY black soot build up after 40 years of exhaust gases from the EGR mixing with oil vapors. To avoid having to go through cleaning it again (DIRTY MESSY JOB!) I deleted the EGR by making a custom block off plate for the intake manifold and shoving two quarters into the exhaust manifold hole with the old pipe fitting screwed in (works very well).
From what I can tell throttle body mounted on the air filter box is part of EGR system. Will there be any issues disabling it? Thanks in advance!
1982 Maxima Diesel
1984 Maxima Gasser (Soon to be RB powered)
1977 810 RB20DE (Scrapped 10/31/25)
Re: EGR and Throttle Body Delete
Fortunately, the LD28 intake is two-piece and easily cleaned, unlike my '99 MB E300 with OM606, or the Sentra diesel, or the Rabbit, or . . .
The vacuum-operated valve at the air cleaner box operates at idle to make the engine intake noise quieter, and at certain higher RPMs to get enough EGR flow. You can remove and plug the vacuum line to the diaphragm on that flap valve, and it'll stay open always. No need to get more elaborate than that.
nissan_nerd
asavage wrote: 3 years ago Fortunately, the LD28 intake is two-piece and easily cleaned, unlike my '99 MB E300 with OM606, or the Sentra diesel, or the Rabbit, or . . .
I deleted all the vacuum lines and the flap valve. Cleaned out all the grunge out of the intake (Not Fun), and put in a catch can. No longer have any issues accelerating from a stop, and black smoke is now at a minimum
1982 Maxima Diesel
