SD33Turbo question: IP pump modification
- Been thanked: 8 times
Under-fuelling is fine (though you don't get maximum power) and should (in theory) reduce EGT over NA. Over-fuelling isn't so good
So . . . boost compensation isn't necessary -- unless you want more power and to retain durability
Remember, I'm adding a turbo to an LD28 (and member dslsmoke has done that too) and will not be changing fuelling (initially). I'll be adding the EGT gauge of course.
zen
well then..there is not point in turboing it.if you are going to leave fueling alone..no power increase.no point..just more strain on head gasket..
now increase the fueling,thats a different story!!
so ip needs to have boost/fueling compensation!!! if it didnt manufactors would not bother with it..now would they?
remember i have turboed my sd33..
turbo it
dieselscout80
It is if you require no smoke during low boost, but many diesels have been built that do not have a boost compensator and yes they do smoke till the turbo builds boost. Most NA diesels will smoke too the SD's with the MZ are one of the few that don't smoke.philip wrote:Carey: Looks like "you don't need a boost compensator" is in conflict with "boost compensator keeps engine from smoking in low boost conditions".dieselscout80 wrote:I don't think you need the boost compensator to run the turbo (the boost compensator keeps the engine from smoking in low boost conditions and then when boost is built up it adds fuel for more power) Snip
Carey
So to take best advantage, boost compensation is necessary to control exhaust smoke, power output, and of course exhaust temperatures.
Can it be ran without a boost compensator yes, but that is not the best way. Now days the greenies will take a strong dislike to the smoke too.
If I ever turbo my Tug SD33 I still have my SD33T pump to help make that swap.
Carey
Diesel Scout
My primary goal on my LD28 turbo project isn't more power -- it's less visible smoke. If more power and better mileage comes along with that, those are side benefits. I will probably be adding boost compensation in future, and that mod's goal is for more power, but Stage 1 is: same power as NA + less visible smoke.zen wrote:well then..there is not point in turboing it.if you are going to leave fueling alone..no power increase.no point..
I understand that others have different goals -- I'm pointing out that boost compensation is not necessary -- if you don't add more fuel.
VW put a turbo on the 1.6 and 1.9 IDI engines without increasing fuel and imported them to the US (91-92) and Canada (91-95+). Advertised HP was up from the NA diesel 52hp to 59hp, so some manufacturers did do it.zen wrote:well then..there is not point in turboing it.if you are going to leave fueling alone..no power increase.no point..just more strain on head gasket..
sa
I didn't know that. 7 HP is approx. the amount I'd expect to pick up from the reduced pumping losses that are compensated by the turbo.glenlloyd wrote:VW put a turbo on the 1.6 and 1.9 IDI engines without increasing fuel and imported them to the US (91-92) and Canada (91-95+). Advertised HP was up from the NA diesel 52hp to 59hp, so some manufacturers did do it.
ISUZU 4BDI[3.9] fitted to australian landrovers comes in 2 turbo versions.
1Garret air research turbo with waist gate overboost relief valve and boost compensation.
2 IHI turbo with no waist gate and fuel delay timmer on the back of the IP.
the latter is for low tech military aplication but has better performace.
IHI tractor we have on the farm is the same.it has a rotary IP that is electrically switched like the VE-but by design it has a shut down idle mode for a few seconds.I believe the delay function is used to dampen fuel quantity changes.
In the interests of cost containment, one -could- "curve" RPM/Load fuel delivery to a turbo that provided boost over a narrow range (no boost compensation). But when anticipated boost was short of expectations ... smoke. Surely a crude and vulnerable but cheaper design that gave way when the Environmental Protection Agency got involved.glenlloyd wrote:VW put a turbo on the 1.6 and 1.9 IDI engines without increasing fuel and imported them to the US (91-92) and Canada (91-95+). Advertised HP was up from the NA diesel 52hp to 59hp, so some manufacturers did do it.
sa
Also, the VW had no air throttling / pneumatic governor such as found on many SD engines. Is that correct? That's another factor in optimal fuel delivery.
In legitimate SD33-T engines, which IP was fitted?
philip wrote:In legitimate SD33-T engines, which IP was fitted?
I was curious if a rotary IP was also used in conjuntion with factory turbocharging.
Can't really call the above IP a fully mechanical pump because there is also mixture override based on boost pressure. A diaphragm still influences fuel rack position.
Possibly on the newer ones? Not on the 1980 Scout.philip wrote:I was curious if a rotary IP was also used in conjuntion with factory turbocharging.
So Dave, this is a 1985 Nissan Patrol SD33T. I see it has an aneroid valve positioned horizontally off the rear of the governor housing.davehoos wrote:ebay number 200029776295 -SNIP
The engine appears to have a spin-on coolant filter adaptor (no filter present). AU accessory?
Maybe not. The Seller states that he bought it for a 1985 MQ.philip wrote:this is a 1985 Nissan Patrol SD33T.
Looks like a accel prop to me.I see it has an aneroid valve positioned horizontally off the rear of the governor housing.
Looks like the Secondary fuel filter mounting base to me.The engine appears to have a spin-on coolant filter adaptor (no filter present). AU accessory?
