1982 maxima diesel 5 speed noisy
1982810maximadiesel
- Been thanked: 1 time
Hello I have a 1982 maxima 5 speed diesel and was wondering why my transmission has become noisy. 1 2 3 and 5 sound like a wheel barrel its been doing this now for over a year I thought it was the diff but someone told me it was the transmission.Also on 5th gear out on the interstate its a slight grinding noise accompanied by vibration. Please advise my Datsun has 275.000 miles I have never doneanything to the transmission.Also when the vehicle is idleing and the clutch is not depressed its very noisy once you depress the clutch noise goes away.I just had a new clutch installed last week with all hardware.
Your input is greatly appreciated ASAP i need to take it in on Wed 3/06/07 so I can repair what is needed.
Thanks,
Bill
Thanks,
Bill
I am assuming this article also applies to the FS5W71B transmission that was used in the maximas.
Nissan 5-Speed Transmission Problems
Ben Martin
1982810maximadiesel
click on the link...
Ben Martin
- Has thanked: 5 times
You have a bad front input bearing or front countershaft bearing. You haven't been changing the trans oil, and those brgs are a weak area in the FS5W71b transmission. Follow the link Ben provided for more info.
1982810maximadiesel
1982810maximadiesel
Maybe, maybe not. If run very long with a bad bearing, the gear teeth wear in an abnormal pattern and replacing the brg(s) will not restore quiet operation. BTDT.1982810maximadiesel wrote:275.000 miles I have never doneanything to the transmission.
I change the drivetrain fluids once a year with synthetic.
Do you think if the bearings get replaced the transmission noise will go away?
While I am not certain, I think it's likely that the gasser version of the Maxima transmission is a bolt-in.Would you recommend a new transmission? Where can I get a new one or used?
I can't make a recommendation about replacing the transmission -- you have to have yours apart to ascertain its rebuildability.
1982810maximadiesel
Noise comes from clearances (slack or backlash) being taken up suddenly and when gears mesh less than perfectly. At your stage of things, new gears.1982810maximadiesel wrote:Will it make the transmission at least reliable What do you recommend i do with this transmission?will a rebuild cure the problem meaning I send it out to get overhauled and done. What can I expect? less noise,vibration chatter.
A "rebuild" is "typical soft parts" like bearings, synchros, gaskets, seals, oil. Gears are outside of typical rebulds. Sometimes it is cheaper to get a used trans whose bearings are still good (suggests good gears) and rebuild that gearbox. Then again, you don't know (unless you heard it run) if the used gearbox was quiet or not. To make matters worse, it's not uncommon for the rebuilder to tell you that an all new gear set will get noisy. They just want to cover their behind and keep your expectations low.
I've got 45k on a chattering gearbox in a 720 pickup. All the gears were good but loose. I had it "rebuilt." A few miles from the shop ... as soon as the oil thinned, it exhibited the same idle/neutral/clutch released chatter. It has not gotten worse. But oils DO make a difference. I've tried several. Single grade 90 weight GL3 oil NON HYPOID synthetic. Redline makes such a product. Heavier oil just makes the synchros slip which makes shifting notchy and doesn't quiet anything. Heavier includes 90w-140wt or 140wt.
You'd probably end up spending a lot less $$$ if you threw a junkyard 280zx tranny in there as a replacement. My JY wants $70 for a used 5 speed tranny. It is a FS5W71B as well, so it will bolt right it - ratios are slightly different.
Ben Martin
dlh: Talk to me more of this "C box swap".
Ben: IIRC, the OD ratio is slightly less tall on the diesel version gearset, which at the speeds the OP is talking about driving often, would make enough difference to make me think about retaining the diesel OD gears at the least.
On the 720 SD I had, where I put a '79 gasser trans gearset in it, never gets driven at high enough speeds where the difference in OD matters.
dlh
A few in the z crowd are looking to the c box mod since the B boxes are getting old and harder to get parts for.
Here's a link for the mods needed for the swap. You can also find more in the archives on zcar.com using "240sx transmission swap" or variations.
http://www.atlanticz.ca/zclub/techtips/index.html
http://www.zcar.com/forums/read.php?f=1 ... ply_566791
http://www.zcar.com/forums/read.php?f=1 ... ply_703393
I know there was a thread that had pics of the modified transmission crossmember, but couldn't find it.
run down of mods needed for the swap---
machine the z/zx bellhousing to allow it to use the larger bearing from the sx.
machine the shift rod holes to allow for the larger shift rods from the sx tranny.
shorten the driveshaft.
modify the transmission mount to allow the longer sx transmission.
1982 280zx turbo 4 spd auto
1973 240z, lsd, cv axles
Thanks, both for your accurate summary and the links, which I did read.
