Remote oil filter bracket needed.
crzhors
Post by crzhors »
I've finally posted pix of our CN4-33 marine version in 'users rigs'.As you can see there really is no room to cleanly/efficiently change the old canister oil filter up against the starboard stringer.Is there an adaptor available to route the oil to a remote filterhead?
As I get the picture loading thing practiced I'll post more progress pix.
Thanks, and hope your getting stronger Philip! Hasta, JD
I am not aware of a direct way of remote mounting a filter to the cannister base -- though I once did have our job shop fabricate one to convert my '65 MB 190D from cannister to spin-on, but that involved both heliarc and machining.
What I propose is to investigate if your cannister adapter can be replaced with the US automotive base. If your oil cooler can interface with the US spin-on base, then remote mounting the filter from that point is a snap, as the automotive base is set up to accept the Ford (Wix 51515, Fram PH8A) filter and adapters to pipe the oil off and back from that is an off-the-shelf item and very inexpensive.
USD$12
crzhors
Remote Filter
Post by crzhors »
Thanks Al, Now my quest is finding out who can sell me an automotive style base, I'm sure there are a few out there,I'll bet Philip has one under his bench :wink: Thanks for the links and help! JD 8)
Note that you want one from an SD Four, not an SD33, which typically uses a canister filter mounted horizontally. You can't adapt it because the oil cooler lines are different anyway.
Wix 51282 for SD33(T) in '76-80 IH Scouts etc.
Re: Remote Filter
crzhors wrote: I'm sure there are a few out there,I'll bet Philip has one under his bench :wink:
I'll ask around for "Oil Filter Bracket". Seems there are two versions. For SD22 the "spin-off" design tilts the filter forward about 10-15 degrees.
For the SD23 and SD25 the spin-off filter is verticle (accomendates Bosch VE's injection lines). For the SD22 with Bosck Inline injection pump, you could also use the vertical filter bracket.
Re: Remote Filter
SD22 filter tilts about 10-15 degrees forward from verticle.
SD23/SD25 are vertical.
Re: Remote Filter
I happened across THIS "bracket" for SD's that is SO SPECIAL that it is still unused (could get it for very cost). The unique design is the oil ports using hoses to a remote oil temperature exchanger. The filters are still can/cartridges like your CN4-33. It also has the oil can vertical.
crzhors
Found one
Post by crzhors »
Good morning, Philip, that adaptor is Real Nice, a shame its the old can style...PBknowles found me a base and remote adaptor in his stuff,so I'll order a remote head,and then the challenge of getting it down here to Central America in an economic fashion. Your reprints of the manuals are really helpful, Thanks again,back into my bilge, JD
Re: Remote Filter
philip wrote:I happened across THIS "bracket" for SD's that is SO SPECIAL that it is still unused (could get it for very cost). The filters are still can/cartridges like your CN4-33. It also has the oil can vertical.
Tonight, I JUST HAPPENED to notice this unidentified oil braket details ...
JD: if you still need one, I am parting out this engine and have this:
crzhors
Oil Filter Adaptor
Post by crzhors »
Thanks Al, I received one from PB Knowles and am installing it this week in sunny Panama, I sure appreciate the thought, maybe someone else with an SD22 will jump on the chance. Ciao4now, JD
jaksonflix
Re: Found one
Post by jaksonflix »
crzhors wrote: 19 years ago Good morning, Philip, that adaptor is Real Nice, a shame its the old can style...PBknowles found me a base and remote adaptor in his stuff,so I'll order a remote head,and then the challenge of getting it down here to Central America in an economic fashion. Your reprints of the manuals are really helpful, Thanks again,back into my bilge JD
freefireforpcdl
this is really cool [bruce]
