sd22 into an 89' toyota 4x4?
skiffish
Post by skiffish »
Anyone attempt this conversion. Just curious.
I have a good sd22 motor and the 22re in my toyota needs major work. Big undertaking? : :?
________
Silver Surfer Vaporizer
Hmmm. How to adapt the SD bellhousing bolt pattern to the Toy's trans?
Once that hurdle is cleared, the rest is merely plumbing.
bacho
Post by bacho »
It might be a little late, but this guy mated the w56 to the SD22. He is one of the best fabricators I have ever seen too.
http://board.marlincrawler.com/index.ph ... ;topicseen
1992 nissan pathfinder 4x4
1985 KC 720 4x4
1982 KC 720
Welding the SD starter bellhousing cone to the Toy bellhousing is tough work. There is no provision to adjust the starter drive gear-to-ring gear clearance on either design, so positioning before welding is critical.
I read a few pages worth forward in that thread to see if he had problems with it later, but there are 113 pages in that thread, and when I hit the homophobic shit on page six I gave up . . . someone else will have to dig for the info.
Image Image Image Image Image Image Image Image
bacho
Post by bacho »
It worked fine for him, he took that thing all over the country. However he did swap a toyota diesel into it later for more power. As I understand he built, or someone else has built more than one of those bell housings allowing use of the SD22 on a toyota tranny.
There is some pretty good stuff in there too, such as running a super charger on the SD22 and lots of turbo stuff.
1985 KC 720 4x4
1982 KC 720
bacho wrote:It worked fine for him . . .
It didn't work fine by chance; he had to have done a good setup job, that's not easy. Not a procedure I'd recommend to someone who doesn't have excellent layout skills.
Even aligned, it would still have to be faced (and probably bored) after welding, for long-term bearing reliability.
OTOH, an adapter plate might be fairly straightforward, at least for me. Maybe.
zac1983
Question
Post by zac1983 »
im currently putting a sd22 in a 87 toyota pickup. i dropped the motor in before i checked the size/tread pattern of the motor to tranny bolts?
