vacuum pump
elbow
vacuum pump
Hello all! Im in the later stages of installing a n/a LD20 in my 92 4x4 p/u and was wondering if anyone knows where I might find a rebuilt or new vacuum pump for it. I have one that is cracked and i welded it but would rather do it right. thanks Bob
LD20 in my 4x4
- Been thanked: 8 times
If the vacuum pump is the same as the one used on the LD28 (Gen1 Maxima, 1981-83), I have a couple spares. Promise to take lots of pictures, and I'll send you one for the cost of shipping only. My shipping ZIP is 98368.
I don't seem to have any good vacuum pump pics on file right now, but this is what I have available (click on any pic for larger):
lots of different alt used on LD20 due to the large number of models they fit.
the bluebird 910 ld20 early 1980's looks the same layout as your LD28 units.the later type can be a upside down thing with the piviot bolts on top.some have pipes threaded directly in and push on oil return.and some use all bango bolt conections.
measure the vane width,and when you have them apart the rotor can have different spline ideas.
Bob, PM me your address again (I cannot run a Search on PMs, so I can't find it from last time), and I'll ship one off. I have several spares, they rarely go bad (ie they have little dollar value), and I'm happy to help.
