Sorry for the basic question, but could someone list some of the major differences between the 2? Does someone know the difference in overall length between the 2? Also, are the mounting points very different?
Thanks,
Eric
SD33 compared to LD28
They don't share a single part.
SD33 is 16% larger displacement, pushrod valve actuation, Inline IP. IP is gear-driven. Was available with a factory-installed turbo. The SD series dates back to about 1964. It was designed for agricultural and industrial use, and later adapted for marine and vehicular use.
LD28 is smaller displacement, OHC, distributor IP. IP is belt-driven. Was never offered with a factory turbo (though the Four LD20 was, and the turbo bits from the 280 and 300 Z turbo cars are almost a bolt-on, with compromises). The LD series dates back to about 1980 and is a newer design. The block critical dimensions are based on the then ten-year-old L240/260/280Z Six, though the block is significantly different in deck height and internal casting thickness. It was designed for vehicular use and later adapted for marine and industrial use. The LD28 is a very smooth engine in operation. The ones I've seen and driven have all had significant black smoke however.
I don't know about the length, weight, and mounting point differences. I can measure the length of an LD28 if you wish, I have one "loose" in storage.
ronin
