Still having issues keeping DSL uptime high. I can HEAR static on the line when I connect my old early-70's Western Electric phone (no phone is usually connected to the line). But it comes & goes.
I have a new backup router I bought a couple of years ago, not the same model but same family. I finally got around to configuring it and swapped it in. It's only four years old (but brand-new), as opposed to the old one which was six years old. Let's see if changing the router makes a difference. If not, I'll call Qwest AGAIN and let them hack at it for a while. Sheesh.
New router
Moderator: Nissan_Ranger
At my mother's place in Evanston IL (ie. deep in civilization 1/2 mi north of Chicago) we've had buzzing and static on the DSL line for 3 YEARS! 3 or 4 visits from the tech, two found interference on the lines but pointed at the house wiring. It's intermittent but rythmic when it happens - nothing in this house makes that kind of music!! Besides, it happens when you connect a phone to the service box directly, eliminating all house wires. Some machine around here is cycling and polluting the signal but it's not in this house. Hmmm. now I'm thinking about it maybe I'll test their ground...
IOWs, good luck. <g>
To review: I had nearly trouble-free DSL with a [1] NetGear DG834 router, for years.
After the phone line underground extension of about 12', uptime went to hell.
Tried swapping in the "backup" [2] NetGear DG834G (with wireless, whooppe), no real change.
Borrowed a "supported" [3] Actiontec R1524SU, and the uptime really was much better, but the NAT and port forwarding would die within minutes to hours -- ie DSL was still up, but nobody could "see" the server from the outside.
Bought a newer "supported" DSL router, [4] Motorola 3347 (Netopia, rebranded for Motorola and with special Qwest-only firmware), and installed it 06Aug09, and it has been working really well. Getting many CRC errors and the SN margin is usually pretty bad.
I think this 3347 is just a lot more tolerant of bad lines. Until it gives some measurable error, Qwest won't do a thing for me. Let's see if we can live with it.
Downstream Upstream Max Allowed Speed (kbps) 1536 896 SN Margin (dB) 1.00 6.00 Line Attenuation (dB) 53.00 31.50 CRC Errors 644 34I've seen a downstream SN of -1 (yes, negative). However, the upstream (ie to all of you) stays above 4. So far, I've never seen this router drop out and fail to retrain.
